install-avr-tools
Given Windows with some version of Arduino installed, set the paths to allow using avr-gcc/etc from the command line.
With WINAVR becoming unmaintained, various people including myself are starting to think that the easiest way of getting a basic set of avr-gcc tools installed on your Windows system is to install Arduino, and use the tools that it includes.
But they're buried rather deeply, and a bit of a pain to get to.
The idea with this project it to provide a simple (hah) and easy-to-use batch file that will automatically set the paths for you. Hopefully it will work with a bunch of different versions of Windows, and a bunch of different versions of Arduino.
Note that this ONLY sets paths. No downloading, no copying, no installing of anything. So it's quite fast.
This is coming along "OK." It turns out that windows batch file are not the most elegant programming environment, and some things are a real pain. But I have a proof of concept running on W10...
c:\Users\ww\Documents>avr-gcc
'avr-gcc' is not recognized as an internal or external command,
operable program or batch file.
c:\Users\ww\Documents>.\install-avr-tools.bat
Looking for avr-gcc in current path
No avr-gcc currently installed.
Found at least one Arduino Program
Looks like C:\Program Files\Arduino-1.6 has version:
avr-gcc.exe (GCC) 4.9.2
Use C:\Program Files\Arduino-1.6 ? [y/n]>y
Looks like 1.6+ Install.
Setting paths to include bin and etc
Checking tool versions
avr-gcc (GCC) 4.9.2
Copyright (C) 2014 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\PROGRA~1\ARDUIN~1.6\hardware\tools\avr\etc\avrdude.conf"
avrdude: no programmer has been specified on the command line or the config file
Specify a programmer using the -c option and try again
avr-gcc: fatal error: no input files
compilation terminated.
V1. Ready for Beta test?
bat - 6.71 kB - 02/27/2017 at 08:45
Download
  • Tested on Win7 (32bit)
    WestfW02/27/2017 at 08:41 0 comments
    Working on 32-bit Windows 7 as well...
    Ready for Beta test! Anyone want to give it a try?
  • Now working on 64bit windows
    WestfW02/25/2017 at 11:31 0 comments
    New version uploaded. It searches Program Files, Program Files (x86), and bin (the latter being a good place to put installs of additional versions, especially if you use the "portable" feature, since Modern Windows won't like an application trying to write to the normal system app directories.
    You wouldn't believe how many strange errors pop up when path names contain parenthesis! The windows commands scanner is text-based, and apparently if you have a code block (delimited by parens!), and it includes an expansion of a path variable (containing parens), you start getting mysterious errors about "xxx unexpected here", even though things appear to be working.
    The solution to the other "early evaluation" problems is to have the "late evaluation" instantiation of the script write out a temporary .bat file, which the "early eval" instantiation then "calls"... Gross!
  • Doesn't work on 64bit windows
    WestfW02/24/2017 at 09:32 0 comments
    A new version (a bit cleaner, and fixing the comment-related bugs) has been committed.
    Also, I tried testing with W8.1, and noticed that the current script won't work with 64bit Windows systems (probably W7, W8, or W10); all the previous W10 testing was done with a 32bit install. This is a simple matter of only searching in %ProgramFiles% and not %ProgramFile(x86)%, so it shouldn't be hard to fix.
  • It works, except the comments are broken...
    WestfW02/24/2017 at 08:19 0 comments
    I guess this is a known windows batch problem, but it took me WAY too long to figure out...
    It turns out that windows batch has a comment command "REM" that is ugly, and a commonly used and documented convention where you precede comments with a double colon "::", which is a little bit prettier.
    But double-colon comment have a bug. The following batch file will cause a "cannot find the drive" error!
    if "%1"=="" (
      :: comment1
      ::  comment2
      echo foo
    This is apparently because "::" isn't REALLY a comment command of any kind; it's actually a label. An empty label, which therefore can't be used as a target of GOTO or CALL or anything, and therefore isn't "executed." But cmd.exe doesn't like having two empty labels inside the same () block. Or something. Grrrr...
  • Windows Batch Files: Delayed Evaluation
    WestfW02/23/2017 at 10:44 1 comment
    wiontinuing from previous log...
    With "delayed evaluation", you replace your variable expansions "%A%" with "!A!", and they get expanded just as they are executed (when you'd expect!) But since this was a backward-incompatible enhancement to .bat files (at some time in the distant path, you have to actually turn this on explicitly for it to work.
    The first way that I found to turn this on is to invoke cmd.exe with a "/V" switch. So if I have foo.bat with:
    SET wholestring=AAAA
    for %%s in (first second third forth) DO (
      SET wholestring=!wholestring! %%s
    echo wholestring is %wholestring%
    I can say "cmd /v /c foo.bat", and I'll get the expected "AAAA first second third forth" output. I didn't find a way to turn this on permanently, and it wouldn't be a good thing to ask of the target audience for this script. I thought I could be very clever and automatically detect whether it was in use or not:
    if !SystemDrive! NEQ %SystemDrive% (
      cmd.exe /v /c "%0"
    ) else (
    (if not running in Delayed Evaluation mode, run the same file with /V turned on. Otherwise do the code that counts on delayed evaluation...)
    BUT - you recall our goal eventually is to set the user environment PATH variable. It turns out that when you invoke cmd.exe like this, any changes the file makes to the PATH variable disappear when that sub-execution of cmd.exe exits. :-(
    This is a problem that is probably familiar to anyone who has written any unix shell scripts. The ENVIRONMENT variables and the shell variables are separate - if your copy of the shell (cmd.exe in this case) creates a variable, you have to do something special to get that value "up" into the environment of the parent. All I needed to do was find the cmd.exe equivalent for "export" or "setenv."
    Except, all the windows batch file tutorials/etc that I could find didn't seem to think that there was any problem changing the path in a .bat file script, and so there doesn't seem to be any equivalent for modifying the parent/global variables. It made a certain amount of sense that running a .bat file, and running cmd.exe to run a .bat file might be different, so I went off on a search to find a way to end up setting the path from the original .bat file instead of the sub-process.
    I had thought I had found it with "SETLOCAL EnableDelayedExpansion" command. This turns on delayed expansion, just like running cmd with the "/V" switch. However, the original "SETLOCAL" command (no arguments) has the effect of making all variables used thereafter be local instead of global, including the PATH. Presumably, running "cmd /v" works exactly like stuffing a "SETLOCAL EnableDelayedExpansion" command in your .bat file as the first command.
    There's an ENDLOCAL command as well, that lets you start modifying global variables again. Perhaps I can do what I need with local variables, then turn them off and put the results into global variables? Nope - it seems that ENDLOCAL deletes any local variables that you had, even if they didn't overlap any global variables. I guess that makes sense, since a variable that merely exists can change behavior, and you wouldn't want that to happen accidentally. But grrr - how do you pass information from your "locally careful" code to something that has to operate globally??
  • Windows Batch files: "Early Evaluation"
    WestfW02/23/2017 at 09:54 1 comment
    So... I'm not really a windows person, and this was supposed to a quick and rather brute-force execution of "find all the things that look like Arduino installs, ask the user to pick one, and set their paths to include the executables from the Arduino directory tree." Straightforward and dependent more on being familiar with the various hiding places and tree structures, than on any great windows programming expertise...
    But apparently, Windows puts some "interesting" issues in the way of some pretty obvious usage, and I thought I'd explain some of them...
    The biggest trouble-make was something that I'll call "Early Evaluation" that affects looping. If you write a loop like:
        set wholestring=AAAA
        for %%s in (first second third forth) do (
          set wholestring=%wholestring% %%s
    You might expect, once you get past the weird syntax, to get a final value of the "wholestring" variable as "AAAA first second third forth" (one word appended to the variable for each word in the "for" argument.)
    Nope.
    The way cmd.exe evaluates this is that the body of the loop (the set statement) has variable substitution done first (except for the loop variable.) So in effect it substitutes in the initial value of wholestring four times:
        set wholestring=AAAA first
        set wholestring=AAAA second
        set wholestring=AAAA third
        set wholestring=AAAA forth
    and you wind up with "AAAA forth"
    How does this affect my program? Well, one of the things I want to do is loop through the list of Arduino dirs, and ask whether to use each one, sort of like:
        FOR %%f IN (%ProgramFiles%\Arduino*) DO (
          SET /P confirm="Use %%f ? [y/n]>"
          if "%confirm%"=="y" (
            GOTO gotdir
    But %confirm% gets evaluated early in that loop as well, so it doesn't ask for each file. Well, it ASKS for each file, but for the comparison it always uses the value that %confirm% had before the first loop. Not very helpful!
    Fortunately, Microsoft added a feature that they call "Delayed Expansion" to address this problem...
  • Tested on XP
    WestfW02/22/2017 at 11:38 0 comments
    Tested on WXP (MicroXP, actually) as well.
    I had thought that 1.0.x and the latest versions had different directory structures for the binaries, but it turns out that that's NOT true for AVR. However, some of the intermediate versions (1.5.0 - 1.6.4, I think) DO put even the AVR compiler in %APPDATA%. Unless configured for "portable" operation, in which case things are different again... The script does not currently handle %APPDATA% possibility.
    I suppose that once this is working to my satisfaction, I should think about having a similar tool that installs any other compiler that the Arduino Board Manager has fetched. OTOH, that may be disappointing, because (for example) the ARM compiler has limit chip support included, and might end up with really nasty include paths needed to fetch even those...
    I'm trying to remember if any of my systems will run W7 without a disk swap... :-(
  • 1st version available
    WestfW02/20/2017 at 22:43 0 comments
    Added on Github: https://github.com/WestfW/Arduino-avr-tools-install
    I've put the initial version on github.
    Project hosting is "interesting." Github and version control and an issue-tracker, but isn't very good for discussions or blog-like history entry. Hackaday.io does some of those better, but doesn't have the features that github has...
View all 8 project logs
  • 1
    Step 1
    This should be easy to use. It's for Windows, between WXP and W10.
    1) Install one or more versions of Arduino. 1.0.x or 1.6.5 are known to work; some of the 1.5 and early 1.6 versions might not.
    2) Download the .bat file and put it somewhere that you can find it.
    3) On your PC, open a "command prompt" window, and execute the batch file. Pick a version of the compiler to "install" when prompted.
    4) Now you have command-line access to avr-gcc (and etc), avrdude, and if the Arduino install included make (1.0.x, alas), also "make" and a bunch of unix-like tools.
View all instructions
Rich text editor
morganxaf wrote 09/20/2022 at 18:58 point
I actually have clean tasks and I may want to plenty as a substitute deal with a piece some fussing spherical at the command traces by the way I am talking about it because there are some messages on abwhatsapp download page which helped me to understand it deeply.
d66gie00 wrote 06/12/2017 at 16:53 point
Very interested in this project -- I could not get AS7 to install on 2 different computers (W732 and W7 64). Had previously installed AS6 on both.
Have (slightly ) used AVRDude and think it's great. I have simple projects to do and I would much rather deal with a little some fussing around on the command lines as opposed to firing up some massive system that's complex and apparently fussy.
Would very much like to know when a W7 64 compatible version is available.
Thanks!
