Cable_Cutting_Machine.fzz
fzz -
242.88 kB -
04/15/2017 at 20:39
Download
Kabelabschneidemaschine_2.0.ino
ino -
15.25 kB -
04/15/2017 at 20:22
Download
Cable_Cutting_Machine_silkTop.gto
gto -
935.16 kB -
04/15/2017 at 20:21
Download
Cable_Cutting_Machine_etch_silk_top.pdf
Adobe Portable Document Format -
685.22 kB -
04/15/2017 at 20:21
Preview
Cable_Cutting_Machine_etch_silk_top_mirror.pdf
692.23 kB -
04/15/2017 at 20:21
Preview
Cable_Cutting_Machine_etch_silk_top_mirror.svg
svg+xml -
157.38 kB -
04/15/2017 at 20:21
Preview
Cable_Cutting_Machine_etch_silk_top.svg
svg+xml -
154.92 kB -
04/15/2017 at 20:21
Preview
Cable_Cutting_Machine_pnp.txt
plain -
10.90 kB -
04/15/2017 at 20:21
Download
Cable_Cutting_Machine_silkBottom.gbo
gbo -
383.00 bytes -
04/15/2017 at 20:21
Download
Cable_Cutting_Machine_maskBottom.gbs
gbs -
4.33 kB -
04/15/2017 at 20:21
Download
Cable_Cutting_Machine_maskTop.gts
gts -
5.07 kB -
04/15/2017 at 20:21
Download
Cable_Cutting_Machine_copperBottom.gbl
gbl -
419.66 kB -
04/15/2017 at 20:21
Download
Cable_Cutting_Machine_etch_silk_bottom_mirror.svg
svg+xml -
40.74 kB -
04/15/2017 at 20:21
Preview
Cable_Cutting_Machine_etch_silk_bottom.svg
svg+xml -
39.92 kB -
04/15/2017 at 20:21
Preview
Cable_Cutting_Machine_etch_copper_top_mirror.svg
svg+xml -
421.34 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_mask_top.svg
svg+xml -
47.19 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_silk_bottom_mirror.pdf
19.51 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_silk_bottom.pdf
19.52 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_mask_top_mirror.svg
svg+xml -
48.09 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_mask_bottom_mirror.svg
svg+xml -
40.64 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_paste_mask_top_mirror.svg
svg+xml -
0 bytes -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_paste_mask_top_mirror.pdf
1.12 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_mask_top.pdf
19.83 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_mask_top_mirror.pdf
19.81 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_mask_bottom_mirror.pdf
19.45 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_copper_bottom_mirror.svg
svg+xml -
440.57 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_mask_bottom.svg
svg+xml -
39.83 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_copper_bottom.svg
svg+xml -
437.97 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_paste_mask_top.pdf
1.12 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_paste_mask_top.svg
svg+xml -
0 bytes -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_paste_mask_bottom_mirror.svg
svg+xml -
0 bytes -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_copper_top.svg
svg+xml -
419.00 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_mask_bottom.pdf
19.47 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_copperTop.gtl
gtl -
368.80 kB -
04/15/2017 at 20:20
Download
Cable_Cutting_Machine_etch_paste_mask_bottom_mirror.pdf
1.12 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_copper_bottom_mirror.pdf
100.82 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_copper_top_mirror.pdf
92.28 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_etch_paste_mask_bottom.svg
svg+xml -
0 bytes -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_drill.txt
plain -
3.28 kB -
04/15/2017 at 20:20
Download
Cable_Cutting_Machine_etch_paste_mask_bottom.pdf
1.12 kB -
04/15/2017 at 20:20
Preview
Cable_Cutting_Machine_contour.gm1
gm1 -
395.00 bytes -
04/15/2017 at 20:20
Download
Cable_Cutting_Machine_etch_copper_top.pdf
92.10 kB -
04/15/2017 at 20:19
Preview
Cable_Cutting_Machine_etch_copper_bottom.pdf
application/pdf -
100.66 kB -
04/15/2017 at 20:21
Preview
Kabelschneidemaschine_Langfassung_Fertig.docx
This is the documentation of the cutting-machine. (GERMAN)
document -
4.06 MB -
03/04/2017 at 14:27
Download
