![](https://cdn.hackaday.io/images/8994971508452215236.jpg)
The new keypad encoder is 'All Done!'. It mates up directly with the male headers on the keypad PCB, so no need for cables to connect the two. When I design the laser cut acrylic for this section, I'll need to leave some tolerance for the screw holes so I can make sure it sits snuggle together.
