Source code...
09/05/2017 at 11:27 • 0 commentsSource code is published. Happy digging ;-)
Assembled camera
07/10/2017 at 08:34 • 1 commentLego Minifigure for size reference :-)
Germanium lens attached
07/10/2017 at 06:08 • 0 comments0,5 mm thick Germanium lens is used to cover the camera hole. Germanium is totally transparent for thermal radiation, but looks like a shinny metal plate in visible light:
Side project: Arcade GAME!!!
06/27/2017 at 07:31 • 0 commentsA small side project implementing a circular pacman like arcade game.
Real time vector graphics using the libfixmath library.
Shutdown effect...
06/22/2017 at 10:19 • 0 comments -
Assembling the camera I.
06/10/2017 at 13:49 • 0 commentsThe components ( PCB, battery, OLED ) nicely fit in the 3D printed case:
Have a look inside:
First Thermal image
06/02/2017 at 10:44 • 1 commentThe first thermal image captured by the device:
75 fps OLED display
06/02/2017 at 10:36 • 0 commentsA quick test about the speed of the implemented 16 bit parallel OLED display connection.
Image export to SD card
05/26/2017 at 07:14 • 0 commentsUsing the Atmel ASF sd_mmc stack and FatFs port, the image export already works!
The first test image, the thermal palette:
First hearth beat
05/08/2017 at 08:32 • 1 commentMost of the components are soldered!
The already working functions:
- Battery charger
- In-system programming / debugging
- Atmel MCU
- Software controlled power supply, the MCU can switch on and off the following power lines: Raw battery voltage (3.7V) - 2.8V - 1.2V - 18V
x-labz
