I got something unexpected while looking for easy/simple/light ways to probe if the server is up with a bash script.
> ./serv_simple === And now, browse to 127.0.0.1:60075 === Port: 60075, Keepalive: 10s Path: files Root page: index.html Warning: chroot() failure (are you root ?) : No such file or directory Server socket ready H_BLOCKED
On the script side:
root@pi:/home/pi# echo "GET /" | telnet 127.0.0.1 60075 Trying 127.0.0.1... Connected to 127.0.0.1. Escape character is '^]'. Connection closed by foreign host.
and then:
* Connected to 127.0.0.1:39298 HTTaP-Session: 2l1cvf10 H_BLOCKING 0 received 7 --------------------------- GET / * got root trying to read file: index.html Extra Header: 25 bytes Content-Type: text/html sending 95 bytes header + 12387 bytes payload : 12482 1 poll() problem on client socket: No such file or directory
Meanwhile I get a kernel message :
[ 2038.025046] TCP: request_sock_TCP: Possible SYN flooding on port 60075. Sending cookies. Check SNMP counters.
OTOH when I change the URL to an invalid one, the server closes the connection itsef and it works.
root@pi:/home/pi# echo "GET /plop" | telnet 127.0.0.1 60075 Trying 127.0.0.1... Connected to 127.0.0.1. Escape character is '^]'. Connection closed by foreign host.
I can thus check the server with this command:
( wget 127.0.0.1:60075/plop -O - 2>&1 | grep 404 ) && echo OK
Or better :
wget -q '127.0.0.1:60075/?' -O - | grep HTTaP
However the poll() failure behaviour is inappropriate and it is now fixed withHTTaP_src.20210106.tgz
Visit us https://www.craftyartapp.com/k/naming-ceremony-invitation-card at to explore our Invitation Templates. Let's enhance your online presence and create memorable moments together!</div>
