HTTaP_src.20210106.tgzfixed poll() race condition that would exit the server, see https://hackaday.io/project/20042/log/187866x-compressed-tar - 51.47 kB - 01/06/2021 at 21:28 |
HTTaP_src.20200515.tgzspeed testx-compressed-tar - 51.37 kB - 05/16/2020 at 00:19 |
HTTaP_src.20200514.tgzBetter graceful close, user call wrapper !x-compressed-tar - 51.00 kB - 05/15/2020 at 03:30 |
HTTaP_src.20200513.tgzmore JS wizardry, and graceful close of the page, among other things !x-compressed-tar - 50.69 kB - 05/13/2020 at 03:03 |
HTTaP_src.20200511.tgzJS client sustains an exclusive connection and other later connections fail as they should. Progressive load of extra images is ok.x-compressed-tar - 49.86 kB - 05/11/2020 at 01:01 |
HTTaP_src.20200509.tgzJS client emergingx-compressed-tar - 48.85 kB - 05/09/2020 at 00:31 |
HTTaP_src.20200506.tgzsession id : okx-compressed-tar - 46.86 kB - 05/05/2020 at 23:53 |
HTTaP_src.20200504.tgzitos(), /?ping=>timeoutx-compressed-tar - 45.64 kB - 05/04/2020 at 00:32 |
HTTaP_src.20200502.2.tgzmore close() bugs, one buffer removedx-compressed-tar - 42.46 kB - 05/02/2020 at 02:38 |
HTTaP_src.20200501.tgzweird close() bugs solved !x-compressed-tar - 42.25 kB - 05/01/2020 at 05:03 |
HTTaP_src.20200428.tgzmore docs, less bugsx-compressed-tar - 41.81 kB - 04/28/2020 at 00:17 |
HTTaP_src.20200427.tgzBetter than the last version ;-)x-compressed-tar - 40.54 kB - 04/27/2020 at 02:02 |
HTTaP_src.20200426.4.tgzx-compressed-tar - 40.24 kB - 04/26/2020 at 18:46 |
HTTaP_src.20200426.tgzreworked system !needs more work but minimal example is functional. one mis-feature needs to be investigated before going further... x-compressed-tar - 40.00 kB - 04/26/2020 at 03:22 |
HTTaP_src.20200424.interim.tgzNot an official revision, but interesting things happen inside !x-compressed-tar - 40.44 kB - 04/24/2020 at 05:20 |
HTTaP_src.20200416.tgzmuch better version, license added, bugs removed, better MIME handling, more control of cache...x-compressed-tar - 37.40 kB - 04/16/2020 at 03:30 |
HTTaP_src.20200415.tgzrefreshed versionx-compressed-tar - 9.21 kB - 04/15/2020 at 08:31 |
HTTaP_src_20170401.tgzTimeout, connection persistence, file serving, etc. are implemented, with crude MIME support through linksx-compressed-tar - 7.75 kB - 04/01/2017 at 08:09 |
HTTaP_src.20170327.tgzNew revision : english comments and variable names, split files, example file... Timeout still not implemented.x-compressed-tar - 4.61 kB - 03/27/2017 at 09:53 |
test_XHR.htmltests serv_11_CORS.c (change the URLs in the source code to point to your own server)HyperText Markup Language (HTML) - 1.58 kB - 02/26/2017 at 07:05 |
serv_11_CORS.cIncludes CORS-compliant headerstext/x-csrc - 11.29 kB - 02/26/2017 at 07:05 |
serv_10_timer.cincomplete implementation of the timeout.x-csrc - 11.09 kB - 02/26/2017 at 05:08 |
serv_9_blocant.ccan change on-the-fly between polling and blocking modex-csrc - 11.03 kB - 02/25/2017 at 23:08 |
serv_8_change-user.cChange the running user and drop access rights (safety if you need to serve files)x-csrc - 10.68 kB - 02/25/2017 at 23:08 |
serv_7_config.cx-csrc - 8.31 kB - 02/25/2017 at 23:08 |
serv_6_1ou0.ca dumb server that understands the addresses 1 and 0x-csrc - 7.36 kB - 02/25/2017 at 23:08 |
serv_6_dualmode.ccan be compiled for either polled or blocking modex-csrc - 7.15 kB - 02/25/2017 at 23:05 |
serv_5_IPv6.cx-csrc - 7.00 kB - 02/25/2017 at 22:23 |
serv_4_FSM.cx-csrc - 4.62 kB - 02/25/2017 at 22:23 |
serv_3_nonblock.cx-csrc - 3.58 kB - 02/25/2017 at 22:23 |
serv_2_reuseAddr.cx-csrc - 2.83 kB - 02/25/2017 at 22:23 |
serv_1_simple.cx-csrc - 2.49 kB - 02/25/2017 at 22:23 |
Yann Guidon / YGDES
