Here is a draft bus layout -
1 +5V +5V
2 +12V +3.3V
3
4
5
6 } 18 pins for other signals
7
8
9
10
11
12 REFSH RESET
13 M1 CLK
14 INT NMI
15 BUSRQ BUSAK
16 HALT WAIT
17 MREQ IORQ
18 RD WR
19 A14 A15
20 A12 A13
21 A10 A11
22 A8 A9
23 A6 A7
24 A4 A5
25 A2 A3
26 A0 A1
27 D6 D7
28 D4 D5
29 D2 D3
30 D0 D1
31 GND GND
32 GND GND
64 Pins Total
56 Pins Signal
8 Pins Power
38 Pins Z80 bus
18 Pins Other signals
XC9536XL has
44 Pins Total
6 Pins Power
4 Pins Programming
34 Pins Signal
Interface 5V CPU to LVTTL Bus
38 Pins Z80
56 Pins Backplane
94 Pins Total Signals
So 3 CPLDs (102 Signals) will interface a Z80 CPU
to the backplane with 8 spare signal pins
One of the spare pins van go to a 50MHz or 100MHz
active crystal oscillator
This will make all but the 8 power pins re-definable
Hacker404
You would want some ground or well decoupled power pins right next to the control signals around pins12 - 18. It is important to minimize the loop area around them to reduce cross talks.
You can get away with the Address/Data if you give sufficient time for setting.
typo : "One of the spare pins van go to"
Important advice : at least spread the GND throughout the buses, like 2 GND in the data bus and 4 GND in the address bus, it helps a bit with noise immunity... Works with other "non switching, low impedance" (and decoupled) signals as well such as 3.3V, 5V, 12V
