Transform Your Dead Scooter To A Dewalt Battery-Powered Electric Scooter!
Dewalt holder no holes.stlBattery Holder STLStandard Tesselated Geometry - 90.90 kB - 11/24/2024 at 03:05 |
IMG_0365.movScooter Testquicktime - 4.32 MB - 11/24/2024 at 03:05 |
I chose DeWalt batteries because they were readily available, but other brand batteries will work as long as you ensure the correct voltage and compatible holders.
⚠️ Important: Check your scooter’s voltage and current requirements before starting.
To connect two batteries in series:
Determine where to mount the batteries. Your chosen location should:
I mounted the batteries near the folding mechanism, as it was narrow and had two screw holes on each side. This area also keeps the batteries out of the way during rides.
Electric scooters often have their battery located in one of two places:
I chose to:
🛠️ Tip: This allows the motor to stay connected to the mainboard while reusing the battery cells for other projects.
After removing the cells, reassemble the battery pack and place it back in the scooter to maintain the motor’s connection.
Here’s a helpful YouTube video that explains how to disassemble the GoTrax GXL V2 battery pack.
