Hornet Nest Alarm Panel
The Hornet Nest Alarm Panel is a PoE-enabled security panel integrating wired systems with Home Assistant and ESPHome, offering 42 zones.
Public Chat
The Hornet Nest Alarm Panel is a cutting-edge, open-source security panel designed to integrate traditional wired alarm systems with modern smart home platforms like Home Assistant and ESPHome. This PoE-enabled panel supports seamless connectivity and automation, making it an ideal solution for hobbyists, professionals, and integrators aiming to upgrade their security infrastructure.
Key features include 42 optoisolated zones/inputs for robust security monitoring, 3 relay outputs for 12V devices, and a pre-flashed wESP32 microcontroller, simplifying setup and customization. The device’s design prioritizes adaptability and reliability, leveraging open-source principles to ensure transparency and user-driven innovation. Whether retrofitting an existing alarm system or building a new one, the Hornet Nest Alarm Panel empowers user
Status:
Stay tuned for updates and subscribe to our Crowd Supply campaign!
Key Features
  • Power over Ethernet (PoE): Enables streamlined installation with both power and network connectivity through a single cable.
  • 42 Optoisolated Zones/Inputs: Provides reliable and robust monitoring for contacts, sensors, and other digital I/O devices.
  • 3 Relay Outputs: Designed for controlling 12V devices, such as sirens, strobes, or other auxiliary equipment.
  • Pre-Flashed wESP32 Module: Includes ESPHome firmware for immediate out-of-the-box compatibility with smart home systems.
  • Thermal Management: Integrated thermal heat sink ensures efficient cooling of the wESP32 module during operation.
  • Flexible Power Options: Operates seamlessly with PoE or an external 12V power supply, offering versatility in installation environments.
  • 3-12V DC Trigger Input: Compatible with a wide range of triggering devices.
  • Integrated Digital I/O Circuitry: Supports enhanced sensing for smart automation and security applications.
Specifications
  • Dimensions: 262mm x 188mm.
  • Open-Source Licensing: Licensed under the GNU General Public License and the MIT License, ensuring accessibility and transparency.
  • Platform Support: Fully compatible with Home Assistant and ESPHome for seamless integration into smart home ecosystems.
  • User-Centric Design: Provides easy customization and supports a variety of applications including environmental monitoring, access control, and smart automation.
Licensing
  • Open-source hardware and software design, licensed under GNU GPL and MIT licenses.
SCH_AlarmPanel_2024-08-24.pdf
Adobe Portable Document Format - 2.48 MB - 11/26/2024 at 14:44
Preview
  • Why I Created the Hornet Nest Alarm Panel
    Christopher Greenlee11/26/2024 at 14:56 0 comments
    When building my new home, I wanted a robust yet smart security system that could integrate seamlessly with my Home Assistant setup. Like many DIY enthusiasts, I initially considered two options: hacking together multiple ESP32 boards to achieve the necessary input/output capacity or buying a pre-made solution from the market. Neither approach quite hit the mark.
    The pre-made systems available were either overly simplistic or lacked the specific customization and integration I needed. On the other hand, cobbling together multiple ESP32 modules felt inefficient and prone to instability, especially with the number of zones I wanted to monitor.
    I realized that what I really needed was a single, purpose-built device with ample inputs and outputs, reliable power (like PoE), and seamless integration with ESPHome. With my background in technology automation and embedded systems, I decided to build exactly what I wanted: a dedicated alarm panel tailored for modern smart homes.
    Originally, the Hornet Nest Alarm Panel was just a personal project, crafted to meet my specific needs. However, as I shared my progress with friends and online communities, I received an overwhelming amount of support and feedback. Many people suggested that others in the Home Assistant ecosystem might benefit from such a board. After much thought, I decided to make the Hornet Nest Alarm Panel available to the public.
    This project grew out of necessity but evolved into something much greater, thanks to the encouragement of the community. My goal is now to offer this solution to others who want to bridge traditional wired alarm systems with modern smart home setups without compromises.
    Check out the project here: Hornet Nest Alarm Panel on Crowd Supply.
View project log
Rich text editor
