0.3.0 : Replace stcflash by stcgal -> stc15 best process, add STC15W408AS-DIP16
0.3.1 : Bugs fixed
0.3.2 : Mini bugs fixed. Primary linux beta version ready : See dependencies packages installation.
0.3.3 : Mini bugs fixed. Speed uplaod bug fixed / choice speed upload menu added
0.3.7 : Add Serial.readString / Add push-pull output configuration for STC micro-controllers
#Todo
analogRead, analogWrite etc...
#Installation and test
1/ Donwload Arduino >= V1.8.19
2/ Launch Arduino
3/ In Arduino->Preferences->Additional Board Manager URLS
    add http://bacciel.com/tools/package_ardui89_index.json
4/ In Tools->Boards:...->Board Manager
    search "8051"
    select and install "ardui89 8051 family Boards"
5/ In Tools->Board:...
    select "Board : "STC89C51" "STC89C52" "....""
6/ Demos :
    Use Blink.ino in basics examples or in Ardui89_demos path :
    Hello.ino
    Howareyou.ino
    and build and upload !
#Linux Dependencies
python3 / python3-pip / stcgal / sdcc
Under terminal :
1/ Installing stcgal :
sudo apt-get install python3 python3-pip
sudo python3 -m pip stcgal
2/ Installing SDCC :
sudo apt-get install sdcc
Many thanks
Cyril BARBATO
http://bacciel.com
cyril.barbato@gmx.com
# Arduino <=> 8051/89C5x/STC32G12K128 pinout equivalent
(Ardui89 Cinque Uno/Due/128k R0)
D : Arduino digital pins
A : Arduino analog pins
LED_BULTIN : D13 (P3.5)
 D        D  A
 7 P1.0 -------|  1  P1.0              VCC  40 |------ VCC
 8 P1.1 -------|  2  P1.1             P0.0  39 |------ P0.0 (AD0) 31 A7
 2 P1.2 -------|  3  P1.2             P0.1  38 |------ P0.1 (AD1) 30 A6
 3 P1.3 -------|  4  P1.3             P0.2  37 |------ P0.2 (AD2) 29 A5 SCL
 4 P1.4 -------|  5  P1.4             P0.3  36 |------ P0.3 (AD3) 28 A4 SDA
 5 P1.5 (MOSI)-|  6  P1.5 (MOSI)      P0.4  35 |------ P0.4 (AD4) 27 A3
 6 P1.6 (MISO)-|  7  P1.6 (MISO)      P0.5  34 |------ P0.5 (AD5) 26 A2
 7 P1.7 (SCK)--|  8  P1.7 (SCK)       P0.6  33 |------ P0.6 (AD6) 25 A1
    RST -------|  9  RST              P0.7  32 |------ P0.7 (AD7) 24 A0
 0 P3.0 -------| 10  P3.0 (RXD)   (VPP) EA  31 |------ EA   (VPP)
 1 P3.1 -------| 11  P3.1 (TXD)  (PRG) ALE  30 |------ ALE  (PRG)
10 P3.2 -------| 12  P3.2 (INT0)     /PSEN  29 |------ /PSEN
11 P3.3 -------| 13  P3.3 (INT1)      P2.7  28 |------ P2.7 (A15) 23
12 P3.4 -------| 14  P3.4 (T0)        P2.6  27 |------ P2.6 (A14) 22
13 P3.5 -------| 15  P3.5 (T1)        P2.5  26 |------ P2.5 (A13) 21
14 P3.6 -------| 16  P3.6 (WR)        P2.4  25 |------ P2.4 (A12) 20
15 P3.7 -------| 17  P3.7 (RD)        P2.3  24 |------ P2.3 (A11) 19
  XTAL2 -------| 18  XTAL2            P2.2  23 |------ P2.2 (A10) 18
... Read more »
