Building a Mechanical Keyboard
A DIY 60% mechanical keyboard based on Cherry MX blue switches
I’ve ordered a Satan PCB board, a case and a plate to finish my keyboard.
Initial idea was to use a laser cuter but it’s not easy to get  access to one.
View all 7 components
  • Using a aluminum case and PCB
    Grégory Paul • 08/05/2018 at 14:06 • 0 comments
    I’ve found some PCBs and aluminium case shell on ebay so I ordered that to finish my keyboard.
    I won’t be was i was thinking at first (using a laser cutter to build the « plates » myself) but at least, I will finalize that keyboard and make use of my Cherry switches.
  • 3 keys prototype
    Grégory Paul • 05/15/2017 at 20:18 • 0 comments
    I’m building a 3 key prototype. It’s pretty ugly since it was cut « by hand » but the idea is to test it before using a laser cutter.
    The keyboard is working using https://github.com/tmk/tmk_keyboard/
    Now it’s time to customize the keys (mute, volume up and down).
  • Wonderful webapp to design the layout
    Grégory Paul • 03/06/2017 at 20:16 • 1 comment
    I just found out about keyboard-layout-editor.comkeyboard-layout-editor.com and http://www.keyboardcad.com/.
    Theses tools allow you to design your keyboard and then generate the SVG to laser cut it.
    It makes thinks really easy. Wonderful !
  • Next, the case !
    Grégory Paul • 03/05/2017 at 14:48 • 0 comments
    The case
    The next part of the process is to design and build the case.
    The case is composed of 4 plates :
    1. the « base » plate where switches will be mounted,
    2. the « supporting » plate,
    3. the « spacer » plate,
    4. the bottom plate.
    In picture :
            _
         __|_|__
    |                | 1.5mm « base » plate
    |   \_______/    | 5mm « supporting » plate
    |     |   |      | 5mm « spacer » plate
    |                | 5mm « bottom » plate
    The goal is to design 4 SVG files that will feed a laser cutter.
    Since I’m not familiar at all with that process, I'm thinking to first design a 3 keys keyboard (volume up, down and mute).
    That will limit the costs if things goes wrong.
  • Components ordered
    Grégory Paul • 03/05/2017 at 14:44 • 0 comments
    Inspiration to build my mechanical keyboard came from an article from « beastie.lesfurets.com ».
    I like the visible micro-controller (a Teensy 2.0) but I’m thinking to use a more traditional layout (without numerical pad).
    Components
    I ordered almost all parts, including :
    • 100 Cherry MX blue switches (face plate mount),
    • 100 diode 1N4148,
    • I also ordered stabilizers parts from wasdkeyboard for large keys (like space, tab, shift and backspace) :
      • Cherry MX Stabilizer Spring for Spacebar,
      • Cherry MX Stabilizer Spring for 2x+ Keycaps,
      • Cherry MX Plate Mounted Stabilizer Clips,
      • Cherry MX Keycap Stabilizer Insert,
    • and, of course, keycaps from pimpmykeyboard composed of
    DSA key means they can be placed anywhere ; other families (DCS or SA) means keycaps are different according the row, see http://pimpmykeyboard.com/key-cap-family-specs/ for further details.
    For the micro-controller, II will reuse a Teensy I already bought.
View all 5 project logs
View all 4 instructions
Grégory Paul wrote 05/15/2017 at 06:00 • point
I won’t use a PCB but simply solder keys one to each other like https://github.com/mathieubolla/sik_keyboard
But you may find keyboard built with a PCB in my keyboard rss feed : https://rsstodolist.appspot.com/?n=keyboard&l=100
Dylan Brophy wrote 05/14/2017 at 23:43 • point
I want to make a keyboard too!  I am excited to see the PCB files.  I got everything but a PCB :D
Grégory Paul wrote 11/12/2020 at 11:05 • point
Sorry for the very late response but I wasn’t able to do the initial project (from ) so I finally used a Satan GH60 PCB & cases (see components)
