Using a aluminum case and PCB
08/05/2018 at 14:06 • 0 commentsI’ve found some PCBs and aluminium case shell on ebay so I ordered that to finish my keyboard.
I won’t be was i was thinking at first (using a laser cutter to build the « plates » myself) but at least, I will finalize that keyboard and make use of my Cherry switches.
3 keys prototype
05/15/2017 at 20:18 • 0 commentsI’m building a 3 key prototype. It’s pretty ugly since it was cut « by hand » but the idea is to test it before using a laser cutter.
The keyboard is working using https://github.com/tmk/tmk_keyboard/Now it’s time to customize the keys (mute, volume up and down).
Wonderful webapp to design the layout
03/06/2017 at 20:16 • 1 commentI just found out about keyboard-layout-editor.comkeyboard-layout-editor.com and http://www.keyboardcad.com/.
Theses tools allow you to design your keyboard and then generate the SVG to laser cut it.
It makes thinks really easy. Wonderful ! -
Next, the case !
03/05/2017 at 14:48 • 0 commentsThe case
The next part of the process is to design and build the case.
The case is composed of 4 plates :
- the « base » plate where switches will be mounted,
- the « supporting » plate,
- the « spacer » plate,
- the bottom plate.
In picture :
_ __|_|__ / \ +----------------+ | | 1.5mm « base » plate +----------------+ | | | | | \_______/ | 5mm « supporting » plate +----------------+ | | | | | | | | 5mm « spacer » plate +----------------+ | | | | 5mm « bottom » plate +----------------+
The goal is to design 4 SVG files that will feed a laser cutter.
Since I’m not familiar at all with that process, I'm thinking to first design a 3 keys keyboard (volume up, down and mute).
That will limit the costs if things goes wrong.
Components ordered
03/05/2017 at 14:44 • 0 commentsInspiration to build my mechanical keyboard came from an article from « beastie.lesfurets.com ».
I like the visible micro-controller (a Teensy 2.0) but I’m thinking to use a more traditional layout (without numerical pad).
Components
I ordered almost all parts, including :
- 100 Cherry MX blue switches (face plate mount),
- 100 diode 1N4148,
- I also ordered stabilizers parts from wasdkeyboard for large keys (like space, tab, shift and backspace) :
- Cherry MX Stabilizer Spring for Spacebar,
- Cherry MX Stabilizer Spring for 2x+ Keycaps,
- Cherry MX Plate Mounted Stabilizer Clips,
- Cherry MX Keycap Stabilizer Insert,
- and, of course, keycaps from pimpmykeyboard composed of
- a DSA blank base set - Gray (GTA),
- a DSA blank modifier set - Red (RBD),
- + a DSA Rainbow blank set (to change my DAS keyboard keycaps),
DSA key means they can be placed anywhere ; other families (DCS or SA) means keycaps are different according the row, see http://pimpmykeyboard.com/key-cap-family-specs/ for further details.
For the micro-controller, II will reuse a Teensy I already bought.
