h250_handset.scad
Parametric OpenSCAD file, so you can use different diameter cables, different mics/speakers, and make any other changes
scad -
22.98 kB -
12/09/2024 at 07:49
Download
makefile
makefile to export all of the STLs from OpenSCAD. You'll need to modify this if you're not using a mac
makefile -
1.01 kB -
12/09/2024 at 07:50
Download
h250_full_plate_screwjoin.stl
Printable plate with all parts, assembled with screws
Standard Tesselated Geometry -
7.28 MB -
12/09/2024 at 07:54
Download
h250_full_plate_gluejoin.stl
Printable plate with all parts, assembled with glue and filament pins
7.27 MB -
12/09/2024 at 07:54
Download
h250_full_plate_screwjoin_withbrim_brimparts.stl
Printable plate with only parts that might need a brim for bed adhesion, assembled with screws
5.28 MB -
12/09/2024 at 07:54
Download
h250_full_plate_gluejoin_withbrim_brimparts.stl
Printable plate with only parts that might need a brim for bed adhesion, assembled with glue and filament pins
5.26 MB -
12/09/2024 at 07:54
Download
h250_full_plate_withbrim_nobrimparts.stl
Printable plate with only parts that shouldn't need a brim for bed adhesion
2.01 MB -
12/09/2024 at 07:54
Download
h250_part_earpiece_cov.stl
Earpiece/speaker cover
1.38 MB -
12/09/2024 at 08:09
Download
h250_part_mouthpiece_cov.stl
Mouthpiece/microphone cover
1.39 MB -
12/09/2024 at 08:09
Download
h250_part_cable_retainer.stl
Clamp to retain cable, attached with 2 M3x8mm countersunk self-tapping plastic screws
676.98 kB -
12/09/2024 at 08:09
Download
h250_part_hook.stl
Clip/hook to hang handset from webbing/etc
394.62 kB -
12/09/2024 at 08:09
Download
h250_body_left_screwjoin.stl
Left body piece, assembled with screws
7.25 MB -
12/09/2024 at 08:16
Download
h250_body_right_screwjoin.stl
Right body piece, assembled with screws
8.85 MB -
12/09/2024 at 08:16
Download
h250_body_left_gluejoin.stl
Left body piece, assembled with glue and filament pins
7.09 MB -
12/09/2024 at 08:15
Download
h250_body_right_gluejoin.stl
Right body piece, assembled with glue and filament pins
8.84 MB -
12/09/2024 at 08:15
Download
h250_body_left_screwjoin_withbrim.stl
Left body piece, assembled with screws, can be printed with a brim for bed adhesion
7.21 MB -
12/09/2024 at 08:14
Download
h250_body_right_screwjoin_withbrim.stl
Right body piece, assembled with screws, can be printed with a brim for bed adhesion
8.79 MB -
12/09/2024 at 08:14
Download
h250_body_left_gluejoin_withbrim.stl
Left body piece, assembled with glue and filament pins, can be printed with a brim for bed adhesion
8.77 MB -
12/09/2024 at 08:13
Download
h250_body_right_gluejoin_withbrim.stl
Right body piece, assembled with glue and filament pins, can be printed with a brim for bed adhesion
7.13 MB -
12/09/2024 at 08:13
Download
