After some beep-testing, ocular verification and soldering the only fault I found was a mirrored pinout for the USB module. No problem, just mounted it upside down.
Software testing showed that the new joystick and soft-reset/config button reading worked as expected. Nice, hadn't really tested it before!
The only major fault I found was that the micro-SD module I used had a different pinout compared to the datasheet I used. 3 patch wires solved that. Not very good looking but serviceable.
Next up is trimming the LED resistors to give enough light. The LEDs come from my old stash, so I had no datasheet for them and will have to test my way to a decent current.
The PCB was fault free and I had no problem soldering everything. All faults were my own. I'll fix all the faults, make some improvements and make a final version later. Now it's time to work on the software and think hard on all the possible hardware improvements.
I certainly won't hesitate ordering from PCBX.com again, it all went as smoothly as hoped.
![](https://cdn.hackaday.io/images/8766401734450721549.jpg)
