Fusion USB PD Power Box is equipped with USB Power Delivery technology, it supports dynamic power negotiation up to 100W (20V, 5A), ideal for powering multiple evaluation boards, chips, modules, 12V HDD disks and a wide range of other devices all at once.
This device converts any USB Type-C input, such as those found on mobile phones or power banks, into a configurable power source capable of supplying both fixed and adjustable voltages. It can be used for a range of applications, from basic electronics projects to more specialized engineering tasks that demand precise power control, as well as troubleshooting devices with specific voltage requirements.
Key Features:
# Fixed outputs (3.3V, 2.5V, 1.8V) @4A.
# Adjustable output1 0.5V to 5V @4A.
# Adjustable output2 1.2V to 35V (max 100W)
# 2.54mm (100mil) Pin Headers for powering multiple evaluation boards
# SCPI Command support for remote programming.
# GUI
# Rotary Encoder for adjusting power in 5mV steps for adjustable
Without actual evaluation of the power output, with good oscilloscope probing, and probing technique...it would be nice to see detailed schematics and preliminary evaluation results, in order to do a first level design review...
I’m excited to share my project, the USB PD Power Box, with you. My goal is to create a low-cost, portable power supply that can be used for a variety of purposes at home or in the lab. This project is completely open source, including hardware, firmware, and the GUI, so it’s accessible to everyone.
I’d love to get your feedback to help me improve it. Please share your thoughts about what you like, what you don’t like, and what could be improved or added. With your help, I can refine this design and make it even more useful for everyday electronics projects and professional applications alike.
Thank you for taking the time to check it out, and I’m looking forward to hearing your ideas!
