Concept
07/04/2017 at 01:34 • 0 commentsLet's face it: Every maker and hacker has dreamed about at least once having a robot companion.
But why don't we have them? Because there are some key features missing:
- Supervision problem: If a robot is fully autonomous, it can get pretty dangerous.
- Usabilty problem: If the robot is not general purpose enough, then it will end up eating dust in your garage, if it is too general, it cannot be used practically because you may be needing in other projects.- Replacabilty: A custom robot part can be quite expensive or requiring special tools to create or just elaborate. If the parts are 3D printable, you can get replacements easily because nowadays there is enough possiblities for access.
