Snap Probe
Finally designed a Testing Probe I enjoy using
This tool was born out of a personal need for a reliable and hands-free way to test PCBs. I often found myself struggling with traditional probes that required precise manual handling, especially when working with tiny test points or densely populated boards. The idea was simple: create a tool that could securely hold itself in place, provide stable contact, and free up my hands for other tasks.
The result is this spring-loaded clamp with integrated precision testing needles. It’s designed to work with a variety of PCB layouts, from microcontrollers to small modules. The clamp applies consistent pressure to maintain a stable connection, which is particularly useful when testing for continuity, voltage, or signals over an extended period.
What I appreciate most about this design is how it simplifies my workflow. I can now set up tests quickly, make adjustments without worrying about the probe slipping, and focus on interpreting the results. The lightweight and durable mater
Now. An advanced version is available at https://hackaday.io/project/202616-adjustable-snap-probe
  • 1
    Step 1
    You can download step from makerworld:
    https://makerworld.com/en/models/1002433
View all instructions
CsGetDegrees wrote 01/10/2025 at 15:02 • point
Share build plz
exa.hacker wrote 01/17/2025 at 06:34 • point
muharrem259 wrote 01/08/2025 at 21:49 • point
It's better than saying to someone, can you hold this for a bit?
Bob Flesher wrote 01/08/2025 at 19:42 • point
Excellent design.  With some small changes you have a commercial product line.  Downside is that it can be knocked off tomorrow so protection isn't worth it.  Very cool.
Vojtech Vladyka wrote 01/08/2025 at 07:44 • point
Hi! Love this, do you have STEP files to share?
exa.hacker wrote 01/17/2025 at 06:35 • point
