- Help with PMOS behavior issue for power selector circuit : r/AskElectronics
- For a nmos, due to the body diode, it will conduct current if Vs >> Vd, even if the gate is "Low". Vice versa for PMOS
A project log for Variable Voltage Controller
Desktop device that outputs a variable voltage whose value is controlled by the user.
