- Power Supply:
- 3.3V power for the microcontroller, display and output voltage controller
- Vi = 5 : 30V
- Will power the 3.3V regulator
- Sensed by input voltage and current sensor
- Powers output power converter
- Microcontroller:
- Low amount of processing, low clock speed required, 8MHz, maybe even 4MHz
- Has ADC pins (accuracy not a huge issue here)
- Need 5 (Vi, Ii, Vo, Io) + voltage output controller
- Peripherals: want SPI to communicate with the display
- Display:
- Show 4 rows of text at least
- Vi, Vo, Io and Ii for efficiency
- Possesses an SPI interface
- Output Voltage Controller:
- Outputs 0V to 40V DC
- Use a switching regulator for efficiency
- Adjustable
- Voltage Sensing:
- Vi and maybe Vo will be higher than 3.3V
- Will need to attenuate the value, will use a voltage divider and a voltage buffer
- Current Sensing:
- Will use "in-line" resistor and an amplifier
- Will use "high-side" sensing
- Resistive Current Sensing: Low-Side vs. High-Side Sensing - Technical Articles
