![](https://cdn.hackaday.io/images/5884781736260105342.png)
- This is where I noticed the issue of the MOSFETS Bi-directionality
- Never actually "electrically disconnected" voltage sources from circuit -> likely created erroneous results
- Later tried using the voltage controlled switch "SW" that is native to LTSpice, set Ron = 1 ohm and Roff = 1/10/100 Mohms
- Not sure how to explain it, but there may have been some "odd behavior" with this set up, however I do not believe it is worth my time to look into this
