I needed a teleprompter. I heard good things about Elgato and had about $1000 worth of supplies in a shopping cart on their website before I decided to verify that I would be able to use this in Linux.
A Raspberry Pi powered teleprompter for video recording
See the components list for links to what I used.
You'll need:
If you want to mimic my tripod and camera mount:
The STL file is in the GitHub repository.
I printed this on an Ender 3 with no raft/skirt. The only support that should be needed is on the open sides of the case and the upper section of the cutout (above the hole for the camera). The angle on the back of the case is 45 degrees and should be printable without support.
