Possible CubeSat Design
A project log for GLOBO
Globo: A High-Altitude Balloon for Environmental Monitoring and Climate Research
stephanie-wallenStephanie Wallen 03/03/2025 at 23:380 Comments
The corner pieces of the CubeSat will be securely screwed into place, holding the foam inserts in position. The foam inserts serve the purpose of insulating the system, ensuring thermal protection for the components.
