First Prototype Built
A project log for Man-Portable Active Protection System (MPAPS)
Portable active protection system concept designed to intercept low velocity munitions such as grenades and drone dropped mortars
l-ancL-anc 13 hours ago0 Comments
Built prototype test-bed with components:
Working with MPAPS_movement.ino test code that implements degree based aiming commands while keeping track of origin and orientation w.r.t it.
Ran into issues driving the turntable as the lazy susan bearing requires too much spacing from the base for the NEMA 17 to directly interface with the turntable. This necessitated extending the motor shaft with a shaft collar and 5mm aluminum rod, however this proved to be unstable and would work itself loose over time.
