Design has been reworked to implement more clearance for wires to and from Arduino in the base, a bearing system integrated into the print itself that reduces spacing between the base and turntable, and more clearance for wires running from base to turntable motor and turret laser/launcher.
Additionally, motionDetect.py has been created which utilizes a real-time motion extraction filter paired with contour detection using the OpenCV package.
