Starting a new project with intention to create a locomotive for Ikea/ Brio wooden track.
Some features in mind (Not in any good order):
Must have features:
Remote control (physical remote, not only app)
Rechargeable battery
Adjustable speed
Remote control for decoupling
Remote control for track change (steering)
On/Off switch
Nice to have features:
One to many remote control
Charging station
Lights
Sounds
Smoke effects
Status screen/leds
Control application
Rotating magnet for N/S connection
Fist components arrived. Managed to do some initial setup and testing for remote control with ESP-NOW. For the remote control transmitter I hooked up an analog joystick to the ESP32 S3 Zero. The receiver is also ESP32 S3 Zero.
Drive motor is working, not sure is this particular motor best for the task. It is fast, but not so powerful at low speed. Finding N20 motor with correct speed, voltage, torque is challenge. Steering stepper is working also, but has overheating issue as I cannot limit the current for the motor with this simple dirver.
Next steps: Design of the test enclosure to test out drive motor and steering motor on real track.
