A battery or 3 batteries?
A project log for Locomotive for wooden tracks
A locomotive for Ikea/ Brio wooden track. ESP32 + steering + speed control + self decupling
lauriLauri 02/21/2025 at 18:530 Comments
I started with an 18650 battery without any protection electronics, just for testing. It has worked fine so far. My initial idea was to buy an 18650 with a protection circuit or design it on the board myself. After some research, I found that not many toys use Li-ion chemistry, so I decided to explore alternative solutions as well.
What does Brio use? According to this post, at least some of their trains use a 2000mAh 1.2V NiMH battery. That’s not as easy to use in my case, so I measured and found that I could use a 3S NiMH battery as a safer alternative to Li-ion. However, I also discovered that there are not many easy solutions for designing a 3S charger. This TI article suggests that a Li-ion charger could be used for 3S NiMH. If I were to use NiMH, I would buy Eneloop AAA batteries. The price for 3 Eneloop batteries would be between 9-12€.
Instead of trying to find room for 3 AAA batteries, I decided to look for Li-ion batteries locally in a similar price range. I found that a CR123 or 16340 battery would be available, costing around 9€.
The NL169 was locally available and has similar specs to what 3 AAA batteries would have:
Specifications:
Now that the NL169 has been chosen, I can start working on the PCB design.
