• Updates
    eugene • 02/11/2025 at 00:14 • 0 comments
    I made a bunch of updates. Been working on replacing my proof of concept code with more of the Kermit projects e-kermit code. I'd had to comment out a lot due to lack of resources o the Arduino.
    I'm using the decode function from e-kermit now, just modified it a little to use a small fixed file buffer instead of their multiple buffers. Using all of their kermit struct now but added in my file buffer and a the optional fields that HP uses but e-kermit has hard coded.
