Update: A Cheesy Slice of Progress
02/15/2025 at 17:35 • 0 commentsAlright, I have to admit that for the initial release, I rushed things a bit to get the project finished.
While SD1.5 has its limitations in terms of expressiveness, the CFG scale (classifier-free guidance scale) was set too high. CFG controls how strictly the generated images stick to the prompt, but too much makes them look… well, not quite right.
After some tweaking, I've managed to generate (relatively) slightly better images of pizza-ish things.
I also experimented with generating "Something circular" images using SDXL. It's clear that SDXL offers significantly improved expressiveness compared to SD1.5.
