An 8087 Co-Processor Extension Board
For the Schneider Euro PC -
Power-Boost it for 3D Graphics and More!
The 1988 Schneider Euro PC is a neat little and relatively rare all-in-one 8088 IBM XT clone driven by a Faraday FE2010A XT controller and a Paradise graphics chip, like many others from that era. It is somewhat special as it is a keyboard computer, reminiscent of machines such as the Amiga 500 or Atari ST. It comes with CGA and MDA graphics, and 512 KBs of RAM. It even offers the elusive Plantronics extended CGA mode which is great for some games (e.g., the 8-Bitguy's Planet X3 supports it and has quite a few more colors in Plantronics mode).
A big drawback of the Euro PC though is that it isn't equipped with a 8087 co-processor socket. The 8087 was only supported in the later version - the Euro PC II.
Let's fix this - turbo-boost your Euro PC by adding an 8087 and a NEC V20!
Background & Problem
All of this started when I discovered an old TurboC 3D graphics program of mine in my archives that I wrote in 1995 - I just grabbed TurboC 2.01 from the Internet, DOSBox, and was up and running like it was 1995 in no time!
However, back in 1995 I was already a proud owner of a full 486-DX50 (not the half-speed DX/2!), and my 3D Torus (US version: Donut!) graphics program ran at a decent speed of a few frames per second (FPS) - needless to say, this thing flies on DOSbox:
GRA 1
GRA 2
You can find my 3d graphics test programs here, and attached to this project as well (see Files section).
Sadly, I don't own a 486 DX any longer (or any "AT" PC clone from that era). But, given my recent Euro PC acquisition and extensive repair marathon 2 years ago (heck, I even had to design my own Mylar keyboard replacement PCB for it!), I knew this machine would come in handy some day, and that it only waited for its chance to shine by running my old 3D Torus program. After all, my Euro PC is already quite a bit turbo-charged anyhow, as it is fully equipped with an external CGA/VGA card, XT CF Lite "harddisk emulator", MPU401 with Waveblaster Soundmodule for MIDI, an 1 MB RAM card, and even an Adlib clone (yes, think Monkey Island!) All of this is connected to an external industrial ISA bus backplane which makes this possible - I am calling this "The World's most Upgraded Euro PC" for a reason; note that I needed to shield the ISA cable (using a fiberglass-aluminum-braid tape) in order to have the machine run stable at 9.54 MHz, which is the max speed:
And then, with all this compute power (!), imagine my disappointment when I found that my donut program runs at 0.05 FPS on the 8088 Euro PC @ 9.54 MHz! Even the wire-frame version runs at only 0.1 FPS. The ~ 5 FPS that I remembered from my 486-DX50 in 1995 had dropped to about 0.05 FPS (one frame every 20 seconds)! I did not expect this to be such a dramatic difference in compute. Wow!
Given the floating point intensive nature of the 3D graphics program, an obvious solution came to mind: an 8087 had to be added - unfortunately, the Euro PC doesn't have a socket for one! Bummer!
The 8087 was a real game changer back in the day for floating point operations. An 8087 is thus highly desirable for the Euro PC, and is realized with this project:With the new 8087, I then measured a speed-up of a factor of 10 for my graphics program. Still not super fast, but the wire-frame only version of the 3D graphics program now runs at ~1.0 FPS. This was well worth the effort.
Next, I replaced the 8088 with a NEC V20, and gained another ~ 0.2 FPS - the first version of the board was using a shielded ribbon cable, and although this version was running fine at 7.14 MHz, it failed to run stable at 9.45 MHz (the BIOS offers three CPU frequencies: 4.77 MHz, 7.14 MHz, and 9.54 MHz):
In my final version I now use a NEC V20 and the 8087-2 at 9.54 MHz, and it runs stable without any issues in my Euro PC at about 1.2 FPS:
BIOS Display 9.54 MHz and Intel 8087 Diagnostics Program:
BIOS
DIAG
Solution & Printed Circuit Board
I analyzed the differences between the Euro PC and Euro PC II, and determined that it should be straight-forward to add an 8087.
Euro PC CPU Section and FE2010A Controller
CPU 1
FE 1
Euro PC II CPU Section and FE2010A Controller
CPU 2
FE 2
Analysis & Board Schematics
As we can see, both machines use the same Faraday FE2010A IBM XT chipset. All signals are available directly from the CPU socket in both machines, with one difference - the NPINT FE2010 output is connected to the 8087 NPINT pin in the Euro PC II, whereas it is connected to GND in the Euro PC (over a PCB solder jumper). I hence added an NPINT pin header to the extension board to give users the option to manually route an NPINT cable from the extension board to the FE2010A pin if required:
Schematics
Layout
However, in my setup and...
gerbers-v3.1.zip
Gerbers 2nd version - GND plane connected to GND net now.
x-zip-compressed - 173.74 kB - 11/05/2025 at 11:30
Download
3dtorus.zip
3D Torus program executables.
x-zip-compressed - 153.56 kB - 02/15/2025 at 22:10
Download
gerbers-v2.zip
Gerbers
x-zip-compressed - 130.58 kB - 02/15/2025 at 03:44
Download
  • 1 × 8088 or NEC V20
  • 1 × 8087-1 (10 Mhz) or 8087-2 (not certified for 9.54 MHz, so you might be lucky, or not!)
  • 2 × 4.7 k Resistor
  • 1 × 10 k Resistor
  • 1 × PCB (from the Gerbers attached here)
View all 6 components
View all 4 project logs
Stephen.A.Gagne wrote 07/25/2026 at 02:18 point
You mentioned popping out the 8088 & popping in a V20. It actually worked without modification???
About 32 years ago, when my last previous TRS-80 (Model 4P) bit the dust. I picked up a used no-name XT clone running a 10Mhz 8088.   (Of course, it had Dark 1778 or something, so it was a while before it worked right.) I still had my library of CP/M software, so I picked up 1/2 dozen 10Mhz V20s, & tried each one. Not one of them worked.
So I broke out the tech manuals on the 8088 & V20, and, sure enough, found that the 8088 needed a 33% low/67% high clock; whereas the V20 needed a 50% high/50% low duty cycle. So, not only was the clock the wrong shape, it was 180-degrees out-of-phase. It was a fairly simple task to run the clock through a quad-NOR gate IC on a daughterboard to re-form the 8088 clock into a V20 clock (prop delays changed the high/low proportions, inversions correcting the phase). When I tested them, 5 of the 6 V20s worked fine.
I then decked it out with 2mb EMS, a cheap 8-bit VGA card + vga-to-ntsc convertor to use the tv as a 2nd monitor, Soundblaster Pro, Panasonic CD ROM (ran off the SB Pro -- no IDE needed), Teac FD505 dual floppy, a 14400 baud modem, and the cheapest trackball I could get my hands on. I ran all my old CP/M software under V2080.COM, ran my DOS software under 6.22, and ran Windows 3.0mm Real Mode (Radio Shack's version). It was a pretty amazing little gaming machine -- WOLF3D, BSTONE, ROTT, STRIFE, DOOM, DUKE3D, QUAKE & later -- I configured it to run game batch files off the small hard disk, that would run games off the CD, with the bootup configuration files on a floppy, & the runtime files on a ramdisk. Until I accidently fried the motherboard.
So I was quite surprised when  you said you just swapped out the chips.That didn't work for me.
Ken Yap wrote 07/25/2026 at 05:13 point
I'd be surprised if the V20 didn't work as advertised, a drop-in replacement for the 8088. Lots of people have done this upgrade, perhaps even me, but my memory is unreliable. Perhaps there was something in your no-name XT's design that made it incompatible.
Here's something to think about: 10 MHz means a period of 67+33 ns for the 8088, but 50+50 ns for the V20. Perhaps 33 ns was too short for the V20, and inverting the clock made it fall within spec. Perhaps a 12 or 15 MHz V20 would have worked right away.
Stephen.A.Gagne wrote 07/25/2026 at 18:13 point
Yeah, no telling about design quirks, even in a plain-vanilla like I started with (640k memory, 84-keys, green/black monitor, herc card, single dsdd 360k 5.25 floppy, 32mb hd, nothing else). But iirc, the 8088 ALE went true during the low clock, while the V20 ALE went true during the high clock. As I said, 180 degrees out of phase. Perhaps the no-name custom ASIC bus controller was more tightly synchronized to the 8088 clock & bus cycles.
Michael Wessel wrote 07/25/2026 at 15:47 point
Ah, nice memories... DOOM, DUKE3D, QUAKE... those were the days. May 486DX50 got quite an inexpensive speed upgrade back in the day by putting the AMD486DX80 in there (forgot the exact name) - the best 50 bucks I ever spent! Yes, no issues with the V20. However, the first attempts had issues with bus frequency, and it took a while to get it to run stable at 9.54 MHz. But 4 MHz was never an issue. Cheers, Michael
Stephen.A.Gagne wrote 07/25/2026 at 21:33 point
Yeah, even my kids loved the games ... until one Saturday morning I woke up late, and my 5-year old had completely disassembled it, down to every last screw & every socketed chip being removed. He wanted to see what made it work. Of course I freaked, but he went & put it all back together, & it worked 1st time out. 5 years old. Now, he still lives with me, & I can't get him to cook his own food. When I fried it a couple years later, my computer guy sold me a couple DX/4-120s w/ EISA/VESA motherboards. Kept me going w/Windows 98, until I upgraded to K6s & switched over to XP. Man. Day & night.
Michael Wessel wrote 02/18/2025 at 02:10 point
glad you liked it! Yes, they are neat little machines 😀
Screen13 wrote 02/18/2025 at 00:55 point
Magnificent!
It made my day to see one of these working and being upgraded.
