Spectrometer Design Part 1: Choosing the Right Geometry for VIS-NIR Spectroscopy
A project log for JASPER: VIS-NIR SPECTROMETER
Grating-based VIS-NIR Spectrometer: Customizable for spectral range, resolution, SNR, and detector options aided by a software design tool
tony-francisTony Francis • 09/01/2025 at 19:14•0 Comments
The design of a high-performance spectrometer, particularly for the VIS-NIR range, hinges on a fundamental optical component: the diffraction grating. The grating's purpose is to separate incoming polychromatic light into its constituent wavelengths, a process governed by the grating equation. When designing a new instrument, such as the JASPER spectrometer, the choice of a design convention for this equation is crucial, as it dictates the instrument's physical geometry and performance characteristics.
The two most common geometries for spectrometer design are the Czerny-Turner and the Offner (which is a type of Lens Grating Lens, LGL, configuration). A Czerny-Turner configuration uses two spherical mirrors to collimate and focus light, offering excellent aberration correction and a wide spectral range. In contrast, LGL configurations often use transmission gratings and can be designed for more compact applications.
This article will explore two common conventions for the grating equation and their practical implications for spectrometer design.
Convention 1: Fixed Geometry (Φ=α+β)
This approach begins with defining a fixed, total deviation angle (Φ) for the light path within the spectrometer. The angle of incidence (α) and the angle of diffraction (β) are then treated as dependent variables that must sum to this constant value.
The grating equation is given by:
mλ=d(sinα+sinβ)
Where:
With the constraint that Φ=α+β, we can express β in terms of Φ and α:
β=Φ−α
Substituting this into the grating equation, we can solve for the angle of incidence, α:
This non-linear equation can be solved for α as a function of Φ and the grating parameters.
Practical Implications: This convention is common in instruments with a symmetrical or fixed mechanical layout, such as Czerny-Turner or Fastie-Ebert configurations. By fixing the total deviation angle, the designers can optimize the spectrometer's geometry to minimize optical aberrations like astigmatism and coma. This method is often preferred for applications requiring high spectral resolution and excellent image quality across the focal plane.
Convention 2: The Littrow Condition
This method, often referred to as the Littrow configuration, is a special case of the grating equation where the angles of incidence and diffraction are equal in magnitude but opposite in sign (α=−β). A common and very useful variation is when the light is incident on the grating and then diffracted back along the same path. In this case, the total deviation is zero.
The design begins by setting a specific angle of incidence, α, which is defined by the following equation:
This equation is derived from the grating equation under the Littrow condition (mλ=2dsinα), with the assumption that m=1.
Practical Implications: The Littrow configuration is characterised by a very compact and simple optical design. Since the incident and diffracted beams share the same path, a single lens or mirror can be used for both collimation and focusing. This reduces the number of optical components, leading to a more compact, robust, and cost-effective instrument. This method is often used in tunable laser systems and certain types of high-efficiency spectrometers where the angle of incidence is set to optimize efficiency at a particular wavelength. The main drawback is that it often requires a scanning mechanism to move the grating or detector to access the full spectral range.
Comparison and Recommendation
Feature
Convention 1 (Fixed Φ)
Convention 2 (Littrow)
Design Approach
Fixed geometry, solve for angles.
Fixed angles (α=−β), solve for geometry or wavelength.
Optical Path
Deviating optical path.
Zero deviation, "folded" optical path.
Component Count
Typically requires two mirrors/lenses.
Can use a single mirror/lens.
Aperture & Slit
Separate input slit and output aperture.
The input and output can be shared.
Advantages
High resolution, low aberrations, wide spectral coverage.
Compact, robust, high efficiency at a specific wavelength.
Disadvantages
More complex design, larger footprint.
Limited to a single wavelength at a time (if fixed), requires scanning.
For the JASPER spectrometer, the best method depends on the primary design goal. If your priority is achieving a wide spectral range with high resolution and minimal optical aberrations, the Fixed Geometry (Φ) convention is the superior choice. This approach, exemplified by the Czerny-Turner design, provides a stable, high-performance platform for capturing a broad spectrum simultaneously. If, however, the primary goal is a compact, cost-effective, or highly efficient instrument optimised for a single wavelength or a narrow band, the Littrow configuration may be more suitable. Given that you are designing a spectrometer, it is highly likely you will be using the first convention to maximise spectral range and resolution.
We will delve into the details of the design to derive α and β for the fixed Φ configuration in the next blog.
