Introducing JASPER - Just Another Spectrometer? Not Quite!… Built for Right to Repair
JASPER: The Open, Fully Customizable VIS-NIR Optical Bench
This project started with a simple mission: build an accessible, high-performance VIS-NIR spectrometer that empowers users, embraces modularity, and fiercely champions the Right to Repair. JASPER is not a locked-down black box. It is a fully exposed, highly adjustable optical bench designed for engineers, researchers, and makers who need full control over their spectral architecture. We are thrilled to share this next-generation iteration with the global hardware community.
Customizability:
The real magic of JASPER VIS-NIR Spectrometer lies in its mechanical adjustability. JASPER allows you to customize your spectral span, resolution, efficiency, and sensor choice on the fly:
- Adjustable Grating Engine: The diffraction grating is mounted on a precise rotating mount with integrated tip-tilt adjustments. Want to target a specific blazed wavelength or shift your spectral window? Just loosen, rotate, and lock it in.
- Interchangeable Slits & Optics: Easily swap out the optical slit to balance throughput and resolution, or modify the focusing and collimating optics to suit your target application.
- Variable Focal Lengths & Angles: The detector assembly is mounted on a sweeping curved track, allowing you to accommodate different focal lengths and align perfectly with any custom grating angle.
- Dual Detector Compatibility: Choose your sensing paradigm. Plug in a commercial off-the-shelf (COTS) monochrome camera for quick spatial-spectral testing, or drop in our custom line array detector PCB for high-speed, dedicated industrial sorting.
Neon Spectra
Industrial Design
Optical Bench
Join the Journey
We are actively tuning the core firmware, optimizing calibration routines, and refining the open-source manufacturing pipeline. Follow the project for regular build logs, raw spectral data releases, and open-hardware schematic deep-dives!
Tony Francis
Steve Dearden
esben rossel
