PCB and Mounting Bracket
A project log for CIS-4
Cistercian digital clock with minimalist display
danjovicdanjovic 06/27/2025 at 03:110 Comments
The circuit was laid on a standard perfboard PCB. The WS2812B LEDs were soldered on one side and the wiring was done on the other side using low temperature enameled wire.
The bracket was designed in openScad and printed in white PLA
