snapfit and handle version 3.f3d
This is the latest version as of 20/05/2025, not sure if it works, but i tried to make the handle and snapfit better to make the use of it easier. (to add the fork, you have to glue it inside the handle)
fusion -
550.15 kB -
05/20/2025 at 15:28
Download
snapfit and handle version 2_.f3d
This is the version 2 of the handle and snapfit, it works and seems pretty resistant, but is far from perfect.
fusion -
408.54 kB -
05/20/2025 at 15:27
Download
Latest version of snapfit and handle, with spikes_.f3d
In this file, there are the version 1 and 3 of the snapfit and handle, and some test for the snapfit.
fusion -
1.03 MB -
05/20/2025 at 15:16
Download
snapfit and handle first version.f3d
This file has both the version 1 of the handle and of the snapfit, it did not work because it was too fragile because it was thin, and since it was short, it doesn't even work.
fusion -
532.69 kB -
05/20/2025 at 15:13
Download
handle version 1.f3d
The first version of the handle for the fork that goes inside the snapfit, did not work.
fusion -
534.51 kB -
05/20/2025 at 15:13
Download
snapfit version 1.f3d
The first version of the snapfit, did not work.
fusion -
80.18 kB -
05/20/2025 at 15:12
Download
