Hackaday.io Hackaday.io
Sign up Log in
MeshWalkie
MeshWalkie: A handheld Compact Wireless Multi-Tool for Lora and Hackers.
openembedOpenEmbed
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
10.4k views
6 comments
109 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 6
View Gallery
10.4k
6
109
75
Team (1)
  • openembedOpenEmbed
Join this project's team
hardware
ongoing project
Related lists
otros
otros varios
General
Projects to come back to
This project was created on 03/03/2025 and last updated a year ago.
Description
It also is a ready-to-use individual Meshtastic and Wi-Fi devices. It's fully open-source and customizable. So you can extend it in whatever way you like.
Components
  • 1 × UV-K6 enclosure (Enclosure ONLY)
  • 1 × ESP32-S3-WROOM-1
  • 1 × Wio-SX1262 lora module
  • 1 × L76K GNSS module
  • 1 × 128*64 LCD with ST7565 controller
Project Logs
Collapse
  • PCB TOP
    OpenEmbed • 04/23/2025 at 09:53 • 0 comments
  • The finished PCB
    OpenEmbed • 04/23/2025 at 09:51 • 0 comments
  • Main components
    OpenEmbed • 03/07/2025 at 04:44 • 0 comments
  • The BETA version PCB design has been done.
    OpenEmbed • 03/07/2025 at 04:32 • 0 comments
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
apocsantos wrote 01/05/2026 at 12:02 • point
Do you expect to release a version in the 866mhz anytime soon? Maybe on Tindie, or some other platform ?
zyndram wrote 05/18/2025 at 17:46 • point
Please look at https://reticulum.network
I was thinking about simple KISS interface K1-USB not whole radio ;-) but Your project look nice.
Andrea wrote 05/11/2025 at 06:05 • point
hello, your project is really interesting! My 2 cents will be about including M17 to the board and LoRa at 433MHz for us amateur radio that can use more power in this band, please.
Bertrand Selva wrote 04/24/2025 at 10:50 • point
Very impressive ! Is there any gain after the SX1262? What kind of range does it give? By the way, it's only for textual exchanges, right? You input the text via keyboard?
edisondotme wrote 03/13/2025 at 14:06 • point
You took a UV-K6, removed the internal components, fabricated your own PCB, and put it back in the enclosure? Impressive!
What was the motivation to use the same enclosure instead of a 3D printed enclosure?
OpenEmbed wrote 03/15/2025 at 02:22 • point
Yes, i only use the enclosure of UV-K6.
The reason is the molding is too expensive, for about over 20k USD.
And the 3D printed is not rugged enough. Maybe it can be a prototype, not end
product.
Tutorial of design and manufacture of PCB prototype "ESP-LoRa" ESP8266 + LoRa with PCB manufacturer Seeedstudio
Project Owner Contributor
10 PCB's Professionals with SeeedStudio ESP-LoRa
undefined
Let's explore the New generation of PCB assembly service with JLCPCB in cheapest cost ever.
JLCPCB SMT Assembly Service-Complete Guide
electroboyElectroBoy
Replace K40's mechanical or broken limit switches with a flexi PCB
K40 Limit switch replacement
paulusjacobuspaulusjacobus
Will introduce 10 free PCB design software and analyze the features of each software
10 Best Free PCB Layout Software
catherine-suiCatherine Sui
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "MeshWalkie", please tell us the reason.
Send message
Remove Member
