Log 4 - 18/03/2025
A project log for Pearl
Design a miniature wooden boat, motorized and remote-controlled, capable of moving forward, backward and changing direction on the water
theoducarnetheo.ducarne 03/18/2025 at 10:240 Comments
Propulsion study and V2 modeling
- Session summary:
Work on the boat's propulsion and the materials to be used.
- What we did:
Study the link between engine and propeller via a drive shaft passing through the hull. Choice of water-resistant materials (stainless steel, brass, engineering plastics).
Revised boat dimensions: 60 cm long, 18.5 cm high.
Start of modeling in Autodesk Fusion. Launch of version 2 (V2) of the boat.
- Results / Progress :
Better adaptation of dimensions to internal layout. Good basis for propulsion.
- What we need to do:
Complete digital modeling of the hull and engine system.
- What we'll do next time:
Finalize the 3D design of the boat on Autodesk fusion.
