Component integration plan
- Session summary:
Designing the integration of electronic and mechanical components into the hull.
- What we did:
Created a box for the battery (via 3D printing), planned attachment with glue.
Suggested mounting of the Arduino board with wires or printed case.
Designed a housing for the steering motor and propulsion motor.
Determination of the location of each component inside the hull.
- Results / Progress :
Clear integration plan, spaces clearly identified. Wiring optimization planned.
- What we need to do:
Print the necessary brackets and validate assembly.
- What we'll do next time:
Finalize box assembly and prepare cabling.
theo.ducarne
