E-Nhale - Air analyzer
E-Nhale is a tool able to analyze the quality of the air by detecting different kind of pollutant in a room
Want to monitor the air quality in your home or workplace ? With an Arduino and some code, you can easily hook up an air quality sensor to visualize all the things!
E-Nhale is a practical object that could be put in any room and will constantly inform you of the principal pollutant their dangers and their quantity, E-Nhale is connected with an app that will directly send the data on your phone and gives you advice to reduce the pollution in the room.
AirtoxWkbk1-2IntroandDefinitions.pdf
Some informations about the air pollution, the risks for your health and the different methods to analyze and gazer data about the air composition.
Adobe Portable Document Format - 190.24 kB - 04/07/2017 at 09:41
Preview
  • 1 × Arduino Uno The sensing brain of the device
  • 1 × Air sensors For : methane, carbon monoxide,hydrogen, humidity, temperature...
  • 1 × Raspberry pi The main brain of the device
  • 1 × Humidity sensor We bought this one embeded with the temperature sensor
  • 1 × Temperature sensor We bought this one embeded with the humidity sensor
View all 9 components
  • Looks great !
    E-Nhale05/31/2017 at 16:02 0 comments
    Finally we managed to get a nice visual for the interface, all the informations needed are displayed even the date ,the time, the temperature and the humidity level =) You just need to click on the gaz you want and the quantity in the air will appear on the screen.
  • Ready to use !
    E-Nhale05/29/2017 at 13:00 0 comments
    E-Nhale is now ready to use but to have your room temperature display on the screen you need to download the library : https://github.com/adafruit/DHT-sensor-library
  • Working on the interface
    E-Nhale05/20/2017 at 18:12 0 comments
    We started to imagine the design we would like for our interface display on our screen, we first decided to do a sketch to visualize our ideas and select the data we wanted to show.
    We then proceed to code it and see if our design is feasible however we didnt achieve our goal yet ^^
  • Finally the design !
    E-Nhale05/20/2017 at 18:03 0 comments
    We selected a soft and handy material, we proceed to cut it with the help of a milling and give it the shape we wanted. We also add the holes for the sensors so it won't overheat inside, we finally added magnet to close the box making it convenient.
  • Calibration of air sensors
    E-Nhale04/28/2017 at 08:48 0 comments
    We started to test our sensors in different conditions, around smoke, water, pollution...
    We configurated them to detect very precisely the amount of gaz in the air. We used different videos on youtube to help us :
  • Pollution everywhere !
    E-Nhale04/07/2017 at 10:27 0 comments
    Still working on the different pollutants presents indoor we found out that your home is full of them. We are thinking of adding some advice on our app in function of the data gathered by the device.
  • Components has arived !
    E-Nhale04/07/2017 at 09:23 0 comments
    Today we received our components including the rasperry pi 3 most of our sensors the screen and the sd card...Still waiting for the bluetooth module but we can start the conception of the prototype with the design we have in mind !
  • The Awaking of E-Nhale
    E-Nhale03/24/2017 at 09:25 0 comments
    It all started from a simple question,
    Can we have a precise idea of the quality of the air around us ?
    We started looking for air sensors and found quite a few that were arduino compatible so yes, it was possible.
    We first wanted to make an all-in-one device that would sense and display the informations about the air but then we thought why not separate the display from the sensing unit. This way, we could have people using our project and adapt it in whatever way they want.
    Here we go !
View all 8 project logs
Rich text editor
