Wi-Fi Router Autopsy
Breathe new life into an old Wi-Fi router: explore hardware - software connections, reverse engineer components, and test security.
In this exciting journey of discovery and learning, I'll be dissecting an old Wi-Fi router I found in the back of a drawer. My goal is to gain a deep understanding of its inner workings, explore security vulnerabilities, and potentially unlock hidden features or repurpose it for new applications.
The subject of this project is the TP-Link TL-WR1043ND ver 1.8, a now-discontinued model that was popular in the early 2010s. Its feature set and powerful hardware for its time make it an interesting candidate for exploration.
Throughout this project, I'll share my methodologies, tools used, and lessons learned. This hands-on approach will not only provide valuable insights into router construction and security but also serve as a learning platform for those interested in embedded systems, network security, and hardware hacking.
Join me as I embark on this Wi-Fi router autopsy, turning an old piece of technology into a treasure trove of knowledge and potential innovation!
Technical Overview of the Hardware
The TP-Link TL-WR1043ND v1.8, released in the early 2010s, is a discontinued wireless N gigabit router designed for high-speed home and small office networks. At its core is a MIPS architecture powered by an Atheros AR9132 system-on-chip (SoC), clocked at 400 MHz. This processor, paired with 32 MiB of DDR RAM and 8 MiB of SPI flash storage, provides sufficient computational power for advanced networking tasks and custom firmware experimentation. The router supports the 802.11b/g/n wireless standards at 2.4 GHz, achieving theoretical speeds of up to 300 Mbps under ideal conditions, although real-world performance depends on environmental factors and antenna configuration.
Basic links
  • 1 × Tp-Link TL-WR1043ND ver 1.8
  • Chapter 1 – Recovering the Passwords
    yaluke15 hours ago 0 comments
    The router had spent the last seven years forgotten in the back of a drawer. During that time, I used a device provided by my internet service provider. After connecting the old router to power, it booted successfully and started serving a network. However, I had no idea what the passwords were—neither for Wi-Fi nor for administration access. Before resorting to pressing the reset button, I decided to experiment and see if I could somehow retrieve the passwords.
    Disassembling the Router
    Disassembly was straightforward, though reading instructions beforehand would have been beneficial—I ended up breaking two fasteners in the process. A quick inspection of the PCB revealed two connectors: one 1x4-pin and one 2x7-pin connector. Documentation found on openwrt.org confirmed these connectors as UART and JTAG interfaces:
    Connecting via UART Using Raspberry Pi 5
    Since I didn't have a USB-to-serial adapter available, I decided to use a Raspberry Pi 5 (RPi) to communicate with the router through UART. The configuration was simple:
    1. First, I enabled the serial hardware interface on the Raspberry Pi using `raspi-config`.
    2. Next, with both devices powered off, I connected them as follows:
    Raspberry Pi 5Router UART
    GND (pin 6)pin 2
    GPIO14/UART0 TX (pin 8)pin 3
    GPIO15/UART0 RX (pin 10)pin 4
    After making these connections, I powered on only the Raspberry Pi.
    Using minicom to Access Router's Serial Console
    The first tool I used for communication was `minicom`, installed on Raspberry Pi with:
    sudo apt install minicom
    Using communication parameters provided by OpenWrt documentation—baud rate: 115200, data bits: 8, parity: none, stop bits: 1, flow control: none—and the RPi UART device (`/dev/ttyAMA0`), the command line looked like this:
    minicom -b 115200 -8 -D /dev/ttyAMA0
    Minicom then waited for data from the router. Upon powering up the router, after a few seconds I saw this output:
    When seeing "Autobooting in 1 second," I quickly typed `tpl` followed by <enter> to interrupt booting and enter the boot prompt. At this prompt, various commands were available (`help` lists them all). However, only one command seemed useful for inspecting memory contents: `md` (memory display).
    Dumping Router Flash Memory
    I assumed passwords were stored somewhere within flash memory, which should be mapped into address space. Based on OpenWrt documentation (flash layout and flashing instructions), I confirmed that flash memory starts at address `0xbf000000` and occupies an 8 MB address range. This was precisely the area I wanted to dump and analyze.
    Minicom offers an option (`-C`) to log all communication into a file. Initially, my idea was to use this feature along with the `md.b` command to dump flash memory:
    Output from `md` can be parsed easily and converted into binary format for an exact copy of flash data. Unfortunately, random chunks of data occasionally went missing during dumping—I wasn't sure if this was due to issues with the router itself, Raspberry Pi hardware limitations, or something else entirely.
    Reliable Data Dumping with Python Script
    To ensure reliable data dumping—checking for missing data and retrying failed reads—I decided to write a Python script using the `pyserial` library (`pip3 install pyserial`). Here's a snippet of Python code that automates connecting to the router's boot prompt (eliminating manual typing of `tpl`):
    import serial
    from time import sleep
    with serial.Serial('/dev/ttyAMA0', 115200, timeout=1) as conn:
            # connect and "login"
            logged_in = False
            buffer = ''
            while(not logged_in):
                x = str(conn.read(), encoding='utf-8')
                buffer = buffer + x
                print(x, end='')
                if len(buffer) >= 24 and buffer[-24:] == 'Autobooting in 1 seconds':
                    # now we have 1 second to "login"...
                    sleep(0.1)
                    # by sending 'tpl' string to device
                    conn.write(bytes('tpl\n', 'utf-8'))
                    # let's read all the stuff before sending next command
                    x = str(conn.read(100), encoding='utf-8')
                    print(x)
                    logged_in = True
    ... Read more »
View project log
