The solar panel with the fan
05/31/2017 at 13:33 • 0 comments -
Electronic board
05/31/2017 at 13:31 • 0 commentsThis is the electronic board !
The kit
05/31/2017 at 13:16 • 0 commentsthis is the box of the kit with the solar panel and the fan
Final Stage
05/30/2017 at 12:48 • 0 commentsWe finished to improve our project and it's working ! It's nice to have a fan like that during these hot days ! ;)
Stage 11
05/30/2017 at 12:46 • 0 commentsWe finished our project, and it's working ! Maybe we can improve our project in one week? We will put in our circuit an LCD display which will show the ambient temperature.
Stage 10
05/30/2017 at 12:37 • 0 commentsWe finished the program and we also find an other solution in order to keep the kit in good condition. We will buy a fan and a battery in order to show that our project is working and, if we replace the battery by the solar panel, it will be the same result. But, because of the time we have left, we have to buy ourselves the fan and the battery.
Stage 9
05/30/2017 at 12:31 • 0 commentsWe are continuing to write the program but we have a problem with the kit. If we want to integrate the kit in the arduino circuit, we have to cut the cable of the fan and we don't want to damaged the kit. We have to find an other solution.
Stage 8
05/30/2017 at 12:23 • 0 commentsWe received the kit. We started to realize the program and build the circuit with the arduino card. It will take few weeks to finish both.
Stage 7
05/30/2017 at 12:06 • 0 commentsWe didn't receive yet the kit with solar panel delivered with a fan and it's connection. However, we had a new idea : make a program in order to control the temperature. We give a reference temperature, for example 20 degrees, and the fan will operate until the reference temperature is reached. We will realize that thanks to an arduino card.
Stage 6
04/07/2017 at 09:39 • 0 commentsWe're gonna talk about our project with our surpevisors. We also found a solar panel delivered with a fans and it's connection, which might actually be very interesting; whether for a car or a smaller project.
