Hackaday.io Hackaday.io
Sign up Log in
THE ULTIMATE MINI ARCADE
Classic arcade with all the latest technological advancements, ready for the classics. Enjoy!
srrubioSrRubio
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
9.1k views
4 comments
22 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 52
    • View all
  • Logs 78
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
9.1k
4
22
23
Team (1)
  • srrubioSrRubio
Join this project's team
  • Video flyers
  • Restrictor aut
  • Restrictor aut + oled
  • Test retrobat + oled
  • Rotary
  • Ambilight
  • Leds doflinx
  • Efecto Hall test
  • Pulsador Arcade efecto hall
  • Test giro pantalla manualmente
  • Test giro pantalla puerto serie
  • Test iluminación panel automático
  • Test iluminación 2
  • Final design
researching project
arcade restrictor ambilight DOF doflinx LEDS
Related lists
Important Video Game Projects
Whether arcade or computer or console, here is a collection of nostalgic interactive media endeavors reflecting the recent past.
Video Games
Both retro and novelty. Games, consoles, controllers, gadgets.
This project was created on 03/10/2025 and last updated 5 小時前.
Description
The idea is to design a classic mini arcade from scratch with all the gadgets I can think of installing: a digital marquee, an automatic joystick restrictor, an automatic rotating screen, analog buttons for racing games, a trackball, a spinner with a button, a rotating joystick, ambilight, automatic light controls... etc.
Files
Joy_xinput_pulsadores_analogicos_autocalibrado.ino
Programa para configurar joy xinput con pulsadores analógicos autocalibrados
ino - 4.10 kB - 04/10/2026 at 20:46
Download
Joy_restrictor_rotary_origen_eeprom_puerto_serie_v2_oled.ino
Programa para pro micro que controla el rotary automático y pantalla oled
ino - 23.93 kB - 04/10/2026 at 20:43
Download
Components
  • 1 × 8.8-inch secondary HDMI screen, 1920x480, IPS LCD display. Para marquesina digital https://es.aliexpress.com/item/1005008270153447.html?spm=a2g0o.order_list.order_list_main.5.6f01194dxBxnbi&gatewayAdapt=glo2esp
  • 1 × FIREBAT AK2 PLUS MiniPC Intel N150 16GbRAM 512Gb SSD https://es.aliexpress.com/item/1005005776132222.html?spm=a2g0o.order_list.order_list_main.32.41e4194dIRqH2K&gatewayAdapt=glo2esp
  • 2 × portatil display of 7 inches IPS 1024x600 LCD. Pantallas stickets animadas laterales https://es.aliexpress.com/item/1005007464814035.html?spm=a2g0o.order_list.order_list_main.38.41e4194dIRqH2K&gatewayAdapt=glo2esp
  • 2 × RASPBERRY PI ZERO 2W - 2WH para pantallas stickers animadas https://www.tiendatec.es/raspberry-pi/gama-raspberry-pi/1735-raspberry-pi-zero-2-w.html
  • 1 × Joystick SANWA JLX-TP-8YT https://es.aliexpress.com/item/1005007250975157.html?spm=a2g0o.order_list.order_list_main.5.781c194dHcXwbU&gatewayAdapt=glo2esp
View all 52 components
Project Logs
Collapse
  • Installing panel led
    SrRubio • 5 小時前 • 0 comments
  • Nuevo diseño panel
    SrRubio • 09/02/2026 at 12:45 • 0 comments
  • Impresión 3D y primeras correcciones
    SrRubio • 09/01/2026 at 16:11 • 0 comments
    Empecé imprimiendo los paneles y he tenido que rediseñar varias cosas:
    - He cambiado la trayectoria de la tira led para no tener que retorcerla tanto.
    - Le he dado más profundidad para cubrir los cruces de la cinta.
    - Olvidé añadir los agujeros para las roscas insertadas del volante.
    Además al unir las piezas con los conectores, el pegamento traspaso al otro lado.
    También he decidido imprimir con la cara de los pulsadores hacia la mesa de la 3D, en las primeras piezas lo hice de lado a lado, cogiendo bastante altura y con mayor margen de errores.
    La tira que compré es de 2m, he tenido que comprar una nueva de 3m
  • Diseño terminado!
    SrRubio • 08/24/2026 at 11:15 • 0 comments
  • Avance en el diseño
    SrRubio • 07/30/2026 at 16:52 • 0 comments
  • Imagen concepto IA previa al diseño final
    SrRubio • 07/16/2026 at 07:45 • 0 comments
  • Mini volante analógico de una mano
    SrRubio • 07/07/2026 at 09:05 • 0 comments
    Para los juegos de coches he pensado en usar un mini volante del tamaño de un spinner. He usado un mecanismo para actuar sobre un mano anaógico como los usados en los mandos de xbox o psx. Pero solo lo movemos en el eje x
  • Altura, ancho, profundo boceto
    SrRubio • 06/23/2026 at 16:05 • 0 comments
  • Boceto CAD Componentes
    SrRubio • 06/21/2026 at 09:42 • 0 comments
  • Conexiones USB
    SrRubio • 06/17/2026 at 10:24 • 0 comments
    Mini PC Firebat
    USB 3.2 #1 → Hub USB 3.0 interno alimentado
    USB 3.2 #2 → Conector USB-A de panel accesible desde el exterior
    Arquitectura:
    Alimentación hub:
View all 78 project logs
Log In/Sign up to comment
Sign up with Github
OR
Arnav V wrote 09/01/2026 at 17:36 • point
Really nice!
SrRubio wrote 06/17/2026 at 19:56 • point
For this mini IPS, in the future I have a 14" TV that screams for a mister fpga
1F409 wrote 06/17/2026 at 15:35 • point
Looking good.  Any chance of non-HDMI, though, so as to avoid feeding the beast?
SrRubio wrote 02/24/2026 at 08:43 • point
You’re welcome
Cyber Clock an IoT OLED Desk Clock With Hygro-Thermometer
Project Owner Contributor
gokuxgokux
The 2016 Hackaday Prize
WiFi networked electro-mechanical 7x7 pixel flip-dot displays as giant DMDs (Digital Micromirror Devices) for low resolution projection
Networked Low Resolution DMD Projectors
michael-shaubMichael Shaub
Arduino byte-banging text and bitmap onto an oscilloscope
HariFun#134 Oscilloscope Abuse
hari-wigunaHari Wiguna
Official Hackaday Prize Entry
My project goal is to make internet access for micro controllers dirt cheap and dead simple to implement in your own projects.
$0.87 WiFi for Raspberry Pi and Arduino Projects
surfingstevesurfingsteve
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "THE ULTIMATE MINI ARCADE", please tell us the reason.
Send message
Remove Member
