YAUTT: Amp your SAO
A hacky bit of HW to easily measure SAO current draw.
0 followers
Yet Another Useful, Trivial Tool: For another forthcoming project I was curious about the current draw of various SAOs. Sure, I could have jumbled together some DuPont jumpers, but I wanted it more easily repeatable, thus this hack.
Foremost, this project was completed based on parts-on-hand.
Some spare parts, a bit of wire wrapping (which I haven't done in cough-cough decades), some soldering and some hot glue. Done. Oh, and a sharpie for the perfect fit & finish ;) .
I was surprised how little current they take... and relatively how much the Hackaday "Supercons Attended" SAO did.
Some may ask - why the male version of the USB connector/power adapter? Because that's what I had. Interestingly, there doesn't seem to exist a female version of it anyway.
Also of note, the female 2x3 keyed headers that were recommended on the SAO Project page are a bit challenging in that the male pins of most SAOs I tried do not fit well, and some force has to be used to insert them (as say, compared to the 2014 Hackaday badge female headers)..
PS. Yeah, the title isn't technically correct, but sounded fun.
  • 1 × USB to 3.3V / 5V DC-DC Step-Down Power Supply Buck Module AMS1117 LDO
  • 1 × 2.54mm 0.1" Pitch Female Header Strip 2x3 Pin With Polarizing Key
  • 1 × 2x8cm (or similar) protoboard
  • 1 × a male to female ("extender") USB cable, optional
  • 1 × a couple single male header pins
  • Small improvements, and next steps
    Todd06/06/2025 at 22:29 0 comments
    I replaced the terrible marker-on-protoboard markings with some quality labels (probably should have used "NC" in place of "X"). And I covered the wiring and leads on the back with hot glue, to protect them and me.
    I plan on redoing this so the "A" measure points work better with another YAUTT... that I haven't published yet.
View project log
