New 8x8 and 16x16 TDM Audio Board for Teensy
A stackable, multi-channel audio board for Teensy 4.x.
0 followers
The CS42448 used in Paul Stoffregen's original multi-channel audio board for Teensy has gone EOL, necessitating a new approach. The TLV320AIC3104 stereo CODEC can be programmed for different TDM slots and has on-board analogue filters. The design has common TDM signals and an I2C multiplexer on each board to allow individual codecs to be programmed.
A Teensy Audio compatible control library is provided alongside a modified TDM driver that transfers odd channel data correctly.
The main PCB has balanced inputs and outputs leading to 6x2 IDC headers, allowing different connector options to suit individual project requirements.
As the TLV320AIC3104 CODECs are QFN (no pins) packages, PCB Assembly is strongly suggested. The main board files provide everything necessary for JLCPCB's PCBA service.
Several 4-channel Wing boards provide input and output connections.
  • Outputs: Balanced XLR and TRS (1/4"). Stereo headphone (1/8")
  • Inputs: XLR, XLR Combo, TRS. An XLR input board with Phantom power.
The hardware repository is at https://github.com/palmerr23/Teensy8x8AudioBoard
The Teensy audio driver is at https://github.com/palmerr23/control_TLV320AIC3104
Boards will be made available on Tindie https://www.tindie.com/products/37676/
The XLR board can be configured as input or output. For correct signal polarity, male (output) sockets are mounted on the underside of the board.
Portable Network Graphics (PNG) - 212.88 kB - 03/15/2025 at 03:20
Preview
XLR Input Output Wing Board Schematic.pdf
Adobe Portable Document Format - 20.64 kB - 03/15/2025 at 03:20
Preview
The TRS wing board for inputs or outputs. The 1/8" headphone jacks are only valid for output connections.
Portable Network Graphics (PNG) - 339.79 kB - 03/15/2025 at 03:19
Preview
TRS Wing Board Schematic.pdf
Adobe Portable Document Format - 28.07 kB - 03/15/2025 at 03:19
Preview
The main PCB. Most connectors have been omitted for clarity.
Portable Network Graphics (PNG) - 317.18 kB - 03/15/2025 at 03:18
Preview
View all 6 files
  • 4 × TLV320AIC3104 Stereo TDM compatible CODEC
  • 1 × PCA9546 Logic ICs / Decoders, Encoders, Multiplexers, DemultiplexersI
View all 2 project logs
