11Step 11
Stick the arduino card on this side. Take care, the micro usb has to be on the edge and fit with the lateral side with a rectangle hole.
12Step 12
Then assemble the lateral sides (the one with an extra rectangle hole is on the usb plug's side)
13Step 13
Download the arduino code then upload it to the card.
14Step 14
If everything works perfectly, you can close the box.
If not, verify if all instructions have been correctly done.
Braille Clock
