Stand-Alone Arduino Bootloader Programmer V3 for A
This standalone programmer simplifies the process of installing the Arduino Uno bootloader onto an Atmega328P-PU microcontroller.
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Key Features:
Microcontroller Support: Atmega328P-PU
Bootloader Installation: Arduino Uno bootloader (5V, 16 MHz)
Interface: USB-C 5V power supply
User Interface: LEDs and buzzer for success/failure notification
Microcontroller State: Supports programming blank or previously used microcontrollers
Speed: Programming takes only about 7 seconds
Benefits:
Standalone Operation: No computer or additional Arduino board required for programming.
Simplified Workflow: Streamlined bootloader installation process.
Wide Compatibility: Works with blank or previously used microcontrollers.
Visual Feedback: LEDs and buzzer provide clear status indication.
Applications:
Programming Atmega328P microcontrollers for custom projects.
Restoring or replacing bootloaders on malfunctioning devices.
Educational and prototyping environments for learning AVR microcontroller programming.
Additional Notes:
Pre-assembled and tested for immediate use.
