Hackaday.io Hackaday.io
Sign up Log in
Cessna 172 engine cluster
Home cockpit cessna 172 engine cluster for X-Plane - MSFS
arturoArturo
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
312
0
4
4
Team (1)
  • arturoArturo
Join this project's team
ongoing project
This project was created on 03/19/2025 and last updated a year ago.
Description
Build process of a Cessna 172 engine cluster for X-Plane / MSFS
Details
Components
  • 1 × Teensy 4.0
  • 8 × x27.168 stepper motor
  • 2 × ax1201728sg
  • 4 × 52mm diameter front glass
Log In/Sign up to comment
Sign up with Github
OR
I mount the roaring jet engine onto a custom-built dolly
Project Owner Contributor
JET ENGINE ON CART (HORRIBLE IDEA)
ibuildit123ibuildit123
Supplyframe DesignLab: 2023 Hackada…
HUGE JET ENGINE TINY CART CRAZY KID -Ian Builder
22kg JET ENGINE POWERED GOKART
I blew up my engine, and am going to remove it, take it apart and fix it. Not really a hack, but it is taking things apart and fixing them.
Toyota MR2 Turbo Engine Repair
scott-sScott S
As we know the necessity of alternative fuel, here may be the solution to it. Acetylene gas can be good alternative for SI engine.
Conversion of SI engine to run on acetylene gas
mapleo333MAPLEO333
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Cessna 172 engine cluster", please tell us the reason.
Send message
Remove Member
