Week 6
A project log for Reaction Wheel Self Balancing Cube
This project attempts to prototype a self balancing cube using three reaction wheels
dami-kimDami Kim 03/21/2025 at 08:050 Comments
Feb 16 - 22
const int potentiometerPin = A0;  // Potentiometer connected to analog pin A0
#define PWM_PIN 9      // Yellow - Speed control (PWM)
#define START_PIN 8    // Blue - Start/Stop
#define DIR_PIN 7      // Green - Direction (CW/CCW)
#define BRAKE_PIN 4    // White - Brake (GND = brake, Floating = release)
void setup() {
    pinMode(START_PIN, OUTPUT);
    pinMode(DIR_PIN, OUTPUT);
    pinMode(BRAKE_PIN, OUTPUT);
    // Set default motor state
    digitalWrite(START_PIN, HIGH);  // Start motor
    digitalWrite(DIR_PIN, LOW);     // Default: CW rotation
    digitalWrite(BRAKE_PIN, HIGH);  // Release brake
    Serial.begin(9600);
    pinMode(9, OUTPUT);  // Set pin 9 as output for tone generation
void loop() {
  // Read the potentiometer value
  int potValue = analogRead(potentiometerPin);
  // Map the potentiometer value to the desired frequency range
  int frequency = map(potValue, 0, 1023, 1000, 26000);
  // Generate tone on pin 9
  tone(PWM_PIN, frequency);
  Serial.print(frequency);
  Serial.println(" Hz");
