Hackaday.io Hackaday.io
Sign up Log in
Robot Gripper
This robot gripper with a pressure sensor uses two serial servo motors controlled by an Arduino to close and grasp an object.
mike-rigsbyMike Rigsby
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
8 followers
  • Description
  • Details
  • Files 11
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
678
0
8
10
Team (2)
  • mike-rigsbyMike Rigsby
  • stevesteve
Join this project's team
ongoing project
Related lists
otros
otros varios
This project was created on 03/24/2025 and last updated a year ago.
Description
I'm working on robot grippers to be used as the "hands" on humanoid type robots. This particular unit needs only to have the selected object placed between the grippers--then a command to "close and grasp" will cause the fingers to close until pressure is sensed. Control is managed by using an Arduino Uno.
Details
Files
two_finger_automatic.ino
ino - 3.78 kB - 03/24/2025 at 21:28
Download
two finger backbone.stl
Standard Tesselated Geometry - 20.20 kB - 03/24/2025 at 21:27
Download
two finger backbone.f3d
fusion - 46.54 kB - 03/24/2025 at 21:27
Download
direction switch.stl
Standard Tesselated Geometry - 94.03 kB - 03/24/2025 at 21:27
Download
direction switch.f3d
fusion - 228.64 kB - 03/24/2025 at 21:27
Download
View all 11 files
Log In/Sign up to comment
Sign up with Github
OR
How we created a Mind Controlled Robot using Arduino which was later converted to a wheel chair.
Project Owner Contributor
Mind Controlled Robot Using Arduino and Mindflex
jithin-sanalJithin Sanal
You'll learn how to construct your first Arduino robot car and create your chassi.
Arduino Robot Car
fcodiegomoreirafcodiegomoreira
You will learn how to build a robot tank with Arduino
How to Make a Tank Robot with Arduino
A 5-bar robot with variable geometry to dinamically ilustrate changes in the spacework of the robot based on its dimensions
Modular 5-bar robot
juan-salvoJuan Salvo
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Robot Gripper", please tell us the reason.
Send message
Remove Member
