Software reconfiguration, part 1
A project log for Calling for hot water, the recall
Updates and expands on my earlier project with new hardware at the water heater.
wjcarpenterWJCarpenter • 03/29/2025 at 04:39•0 Comments
As I mentioned, my first step is to ignore the RS485 stuff and get the hot button mechanism working with this new hardware setup. Because I used ESPHome, things are mostly abstracted. Here are the changes I made based on testing the new assembly:
Here's the YAML so far:
# https://hackaday.io/project/202744-calling-for-hot-water-the-recall
substitutions:
  node_name: hotbuttonrelay-al
  RELAY:  'GPIO26'
  LED:    'GPIO27'
  BUTTON: 'GPIO39'
  log_level: 'DEBUG'
esphome:
  on_boot:
    then:
      # delay to allow other boot time stuff to settle down
      - delay: 5s
      - script.execute: set_led_cold
esp32:
  board: pico32
wifi:
  ssid:      !secret wifi_ssid
  password:  !secret wifi_password
  power_save_mode: high
  fast_connect: on
  manual_ip:
    static_ip: !secret hotbuttonrelay-al_ip
    gateway:   !secret wifi_gateway
    subnet:    !secret wifi_subnet
    dns1:      !secret wifi_dns1
    dns2:      !secret wifi_dns2
logger:
   level: ${log_level}
api:
  encryption:
    key: !secret hotbuttonrelay-al_apikey
  reboot_timeout: 60min
  services:
    - service: set_led_hot
      then:
        - logger.log:
            tag: 'hotbutton'
            level: INFO
            format: "service: set_led_hot"
        - script.execute: set_led_hot
    - service: set_led_cold
      then:
        - logger.log:
            tag: 'hotbutton'
            level: INFO
            format: "service: set_led_cold"
    - service: set_led_off
      then:
        - logger.log:
            tag: 'hotbutton'
            level: INFO
            format: "service: set_led_off"
        - script.execute: set_led_off
ota:
  platform: esphome
  password: !secret ota_password
switch:
  - platform: restart
  - platform: gpio
    pin: '${RELAY}'
    restore_mode: ALWAYS_OFF
    icon: mdi:hot-tub
    on_turn_on:
      - light.turn_on:
          red: 0%
          green: 100%
          blue: 0%
      - delay: 500ms
      - switch.turn_off: i_relay
      - light.turn_off:
# Local test button. This goes through the relay logic,
# so it's not an analog press of the water heater button.
binary_sensor:
  - platform: gpio
    pin:
      number: '${BUTTON}'
      inverted: true
      mode:
        input: true
    filters:
      - delayed_on: 10ms
      - delayed_off: 10ms
light:
  - platform: fastled_clockless
    chipset: SK6812
    pin: '${LED}'
    num_leds: 1
    rgb_order: GRB # required
    default_transition_length: 0s
    icon: mdi:led-on
    effects:
      - pulse:
          transition_length: 0.25s
          update_interval: 0.25s
          min_brightness: 20%
          max_brightness: 99%
script:
  - id: set_led_hot
    then:
      - delay: 600ms  # give the relay blink a chance to show
      - light.turn_on:
          red: 100%
          green: 60%
          blue: 0%
          effect: fast_pulse
  - id: set_led_cold
    then:
      - light.turn_on:
          color_brightness: 20%
          red: 0%
          green: 0%
          blue: 100%
          effect: none
  - id: set_led_off
    then:
      - light.turn_on:
          color_brightness: 0%
          red: 0%
          green: 0%
          blue: 0%
          effect: none
A side note for you young tinkerers: The first time I uploaded the firmware, I forgot to change the configured static IP. That meant an IP address collision with the existing hardware. In short order, both devices were knocked off the air. Don't be like me!
Without physically hooking this new assembly to the water heater, I tested it by configuring it into my Home Assistant automation that glues everything together. Everywhere that I have a reference to the old equipment in the automation and script, I made a cloned reference that instead references the new equipment. That means that the automation activates both the old and new relays. I can hear the tiny click when the new relay is activated.
