Tumble dryer repair
Fixing my Bosch Classixx 7
0 followers
It started making funny noises for a while, then eventually stopped drying at all. I only bought it five years ago, and people are now used to thinking that is old. It looks brand new on the outside. I'm not paying 2 days salary to replace it if there is a simple fix.
£315 original cost in 2020 (£391.65 in 2025 money)
£14.30 drive belt
£7.10 roller
£90 appliance repairer visit
So £111.4 to repair was a lot cheaper than buying a new one (about £449).
View all 3 project logs
jgadbois wrote 04/06/2025 at 15:47 point
"Well, I'm sure I could work it out, given enough time, but it looked like a long time and I would have to buy tools as well"
Buying tools and working out methods is called learning. The first few times will be difficult  but each project makes the next one easier.
Instead of paying to watch someone fix the dryer you could have learned how to find information, use tools learn concepts of operation.
Until you actually fix something your abilities will remain theoretical.
Keith wrote 04/06/2025 at 22:39 point
I've got two science and engineering degrees and a 40-year engineering career.
I'm well aware what learning is, thank you very much. I've designed and repaired many things over the years. However, I am very busy doing a full time job, and many other things in my scarce spare time. I did indeed search for information, and the manufacturers were not giving it out and the demonstration videos did not work with my particular dryer. There is not always the information needed. People are not going to make repair videos for every make and model of every appliance. So I can either (a) spend an open-ended amount of time on a dryer partially disassembled in my kitchen surrounded by growing piles of unwashed and dry or washed and damp clothing and an increasingly impatient wife, or (b) learn how to do it by watching an experienced guy fix it in an hour, then write it down here, thus making the solution available for the benefit of my fellow humans who own this particular appliance.
Rating personal hygiene and my loved ones highly,  I chose clean dry clothes and a happy partner. If you don't have family and don't mind dirty underpants, you can make your own choice.
