This project was started as an experiment to test the productivity of using AI vibe programming. I leaned heavily on Google's Gemini to generate the original outline of the application and iterated on it several times. In the end, I debugged a number of issues in the generated code and added additional formatting and functionality. This original project took less than 6 hours start to finish. This included generating the man page documentation and publishing it to github and here.
The quality of the code is a only so-so. But, it is fully functional. Some additional work to refactor it to be more readable will be done. I will further experiment with AI to refactor code, generate additional documentation, and generate a set of unit tests to improve the code quality. If there is some interest, I can look into adding new features.
You can find the source and installation instructions here on github: https://github.com/racerxr650r/Valgrind_Parser
John Anderson
Martin
Mike Lemberger
Dilshan Jayakody
CHAOS.TANG
